Question about Logitech QuickCam Pro 5000 Webcam
Logitec Pro 5000 not being recognised by USB Port
Just got the Logitech Pro 5000 webcam, it appeared that it set up ok. However the problem is that the computer some times recognises and then at other times it doesn't and if it doesn't recognise the camera in the port it seems to time out. Has anyone experienced this before. i intend using it for Skype.
  • 1 more comment
  • Anonymous Dec 02, 2007
    I am having a problem with the logitech quick cam pro 5000 not being recognized on the USB ports. Sometimes it works sometimes it doesn't.
    I am running a Gateway GMS 479 with Windoz Vista.
  • Lannman Apr 08, 2008
    Trying to Install the Logetic Quick Cam Pro 5000 on a Wyse Thin Client with XPE. Get the following error: Extract: Error writing to file lvcodec2.dll.
    Anyone else had this problem? If so what did you do to correct it?
    GaryE
  • Anonymous Apr 19, 2009
    Thank you 0robert0 you soled my problem.
  • 4 Answers
Hi .
Had same problem:
uninstall quickcam 5000 v11.50 drivers.
install quickcam 4000 v10.51 .
There is few files missing ( /removed) from version 11.50.
rob
Posted on Jan 01, 2008
Thanks rob , that was the problem, my webcam is now working. It keep asking me to update the software. I never let it now.
Steve
Posted on Aug 09, 2009
Same problem, with logitech qickcam pro 5000 v11.7, software loads but cam not recognised
Posted on Dec 02, 2008
Tried this solution but didn't work for me.
Posted on Mar 19, 2008
SOURCE:
How to save with bmp format using logitec quickcam 5000
You can try manycam. Its free and allows you to save in the bmp format
Feb 28, 2011 | Logitech QuickCam Pro 5000 Webcam
Blurring during realtime movement
Try a different USB port if you can.
Check the lighting, to make sure you do not have "low light" conditions, that will affect the picture in a similar way.
Check the focus ring on the front to make sure it is set right.
http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
Dec 18, 2009 | Logitech QuickCam Pro 5000 Webcam
I have the same WebCam and am experiencing the same problem.
I suspect that the voltage drop across the lead is enough to prevent the webcam from working.
Post the question on the logitech forum
Have all necessary information ready
Camera model
OS
Type of USB port 1.1 or 2.0
http://forums.logitech.com/logitech/?category.id=webcam_video
Sep 18, 2009 | Logitech QuickCam Pro 5000 Webcam
Logitec webcam not working since vista service pack download
u do this
controlpanel .....> Add remove programs remove camera software
and install software again also u do change usb port
Jul 01, 2008 | Logitech Webcam
Logitec Quickcam V9.5.5S - Does it support Windows vista
hey if your camera is quickcam pro 5000
then you can find the vista software from here
Logitech Pro 5000
Apr 05, 2008 | Logitech QuickCam Pro 5000 Webcam
Microphone not working
Look in your system tray( next to the clock in the lower right hand side corner)
Locate the Volume Control and double click on it
Verify if the box by Microphone volume isn't muted
Good Luck
-John-
Dec 24, 2007 | Logitech QuickCam Pro 5000 Webcam
I have a pro 4000 logitech webcam
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
Oct 24, 2007 | Logitech QuickCam Pro 4000 Webcam
Webcam
You need to go to logitech's site and get the new version - i believe its 10.15.0 or somewhere around there.
Oct 20, 2007 | Logitech QuickCam Pro 5000 Webcam
Usb extention lead doesn't work with webcam
So you know the cam is ok and the cable, so you will have to point to the usb port not being able to push enough power through the cable to the camera as it must take a higher voltage than the other cam. Make sure that the other cam software is uninstalled and you have done registry clean in case of conflicts and also try using a different usb port but install the camera with the driver again using the extension in it, aplogies if you did, i am assuming you may have installed the camera directly without the extension cable.
Apr 29, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech QuickCam Pro 5000 Webcam Logo
524 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
