Question about Video Game Consoles & Games
I recently bought a used ps3 which came with Hamilton cables only my tv does not use hdmi so I bought av cables but it does not work! What do I do?
  • 4 Answers
You need to reset the PS3 Display. Do This Touch and Hold Power Button On PS3 until it turned off automatically. Then again touch and hold PS3 and you will here beeps. Let go off power button after second beep.
Posted on Jul 18, 2013
Ressetig the ps3 on a new tv
Sounds like the Tv your using is faulty. Its could have hardware failure. You did say it PS3 was working on hdmi on a plasma. If your using the default hdmi cable that came with ps3 that also can be faulty. I have always had problems with the default hdmi so i bought a new one that was not SONY and it works beautifully. Another thing the black screen with green is a video cable or graphics issue.
Does this tv work if there is no ps3 connected? if so i recommend using the standard PS3 Component AV Cable. see if that will let you reset your ps3.
Jun 24, 2014 | Sony Playstation 3 (PS3) Console
I have a new slimline DVD and a sony bravia HD tv. My PS3 worked with the basis cable and I recently purchased an HDMI cable and now it won't work on any of my 6 AV channels, including 1 of the 2 HDMI...
All you have to do is reset the video settings on the PS3. Hold down the power button until you hear a single beep, then press it again.
That should have reset the video settings so you can play on the new TV.
Regards.
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Av connections not giving signal to tv
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
welcome to fixya
you have to set it up on the ps3 for the cable
i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
Aug 01, 2008 | Sony Playstation 3 (PS3) Console
Ps3- hdmi to av
unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
Aug 24, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
