Question about Car Audio & Video
Volvo wheelloader l120e
Fault code EECU PSID 096
Volvo 2014 vnl FAULT P255613
Not sure how you are getting this code, there are no faults codes with that amount of numbers on a volvo, the nearest i can find is a B code B2556 Enable Signal Circuit Short to Battery, P codes only go upto P1918
Mar 03, 2018 | Volvo Cars & Trucks
Volvo S60 2001 MODEL WHAT IS CODE 8227
what an unusual fault code for a volvo
ecu error // ignition keys not being recognized ?
any letters or prefexes with that 8227
OBD II Fault Code P8227
Sep 02, 2016 | 2001 Volvo S60
What is Volvo c70 fault code p0785?
this code refers to shift timing solenoid "A" circuit open this can be the solenoid , the connectors or the wiring if you can recall when it first started was there anything done or fitted to the car
sorry i don't know what solenoid is "A" i am not familiar with volvos i bought a book on fault codes hope this helps
Aug 13, 2014 | Transmission & Drivetrain for Volvo C70
Bmw starting problems
It might be an EECU issue as it's obviously getting fuel to the combustion chambers. Also, it's not displaying any codes which indicate that the EECU isn't registering that it's not working properly (possibly intermittent). First unplug the negative terminal from your battery. Next unplug and re-plug the EECU cable. This works approximately 50% of the time as it resurfaces the connector mating surfaces and on some models allows the EECU to reset. If this doesn't work, try a used low mileage one.
Highly doubtful your ABS module is causing your starting problems unless the problems occurred right after you replaced it.
Also, I suggest you need to find a competent independent local shop that specializes in BMWs. They will have the sophisticated tools necessary to diagnose your issues and turn off your trouble lights as well.
Mar 02, 2017 | Cars & Trucks
Eecu 2007 galant
No idea here ,i remember cars with magnetos and one channel B/W TV .sorry try the dealer if a immobilisor fault
Jul 14, 2013 | Vehicle Parts & Accessories
Volvo v70, rough running, fault codes p2172 p2101
The exact same set of codes have just come up on my car, the same car and year. Did you solve it? I am thinking cleaning the throttle body first, any help appreciated....
Jun 02, 2010 | 2002 Volvo V70
Fault codes on a volvo FH12 rear left lights stay on
Volvo has had a lot of trouble with relays in the rear control module. Check/replace the relays for the rear lights with the updated relays.
Mar 20, 2010 | 2004 Volvo XC70
Flashing f32 fault
Your owner's manual will have fault codes in it. If you don't have 1, you can download 1 here:
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
Jun 04, 2008 | Frigidaire Dishwashers
Car Audio & Video Logo
142 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
