Minolta copier 3050 error code - Office Equipment & Supplies
Tell me about m4 code how can i get rid of it?
Posted on Dec 13, 2013
2 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Minolta Di 3010 Error code C0910
Sorry it took so long but I found it.
C0910 indicates that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there is any jammed paper in there.
Posted on Sep 06, 2008
Minolta 3050 screen
Well then you might have a power supply problem check the fuses in the back also
Mar 25, 2016 | Minolta Office Equipment & Supplies
Minolta 4050 giving error code c0160. and noiw not going ahead of welcome screen
The C 0160 code not exist in Minolta EP 3050-5000 series.If the real code is C0610 refer to lens motion failure.Check the mirror reference position sensor and lens reference position sensor.Unplugged and plugged the connectors. 3331bbd5-f151-4464-a6c0-bf018f48f2bd.jpg
Mar 20, 2014 | Minolta EP4000/5000 CS/PRO Copier
Minolta CSPRO EP 3050 CODE ERROR C0072
Sir/Mam Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Aug 28, 2013 | Minolta EP4000/5000 CS/PRO Copier
Have a Minolta CSPro 3050 with error code C004A. What does it mean
There is a fan located under the big glass section remove the glass an check the fan clean it or replace it.
Feb 01, 2012 | Minolta Office Equipment & Supplies
49 error on HP laserjet 3050
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
Minolta ep 3050 copier error code coo70, toner bottle does not turn. have replaced toner motor.
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner install it correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Nov 01, 2010 | Minolta EP1030/1030F CS/PRO Copier
Error code C0320 for cs pro 3050
Please deescribe your roblem/reset the malfuntiion code open and close the front door or turn OFF the power witch and tray again to turn .
Aug 13, 2010 | Minolta EP4000/5000 CS/PRO Copier
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Hello, I'm having the Error code C0400 when attempting to use Minolta 3050. Can you help?
in minolta this error is for exposure lamp .just check ur exposure lamp.may bi it is dead or supply problem .by mian jee
Nov 21, 2008 | Office Equipment & Supplies
21 people viewed this question
k24674
jasbo
jasbo
