Actron air conditioners P2 fault
P2 fault on Actron split a/c
3 Suggested Answers
SOURCE: How do I fix an e9 error on my am24-1 model actron
That model number is the actual wall controller model number not the air con itself. Go outside get the outdoor unit model number and call actron. Or call an a/c tech to come out.
Posted on Dec 12, 2011
  • 3 Answers
SOURCE: My new gree air conditioner split system has an E1 error
http://www.aliexpress.com/item/2013-Residential-Air-Conditioner-Commercial-Air-Conditioner-Spare-Part-GREE-Air-Conditioner-Remote-Control-Y512/893088745.html
Posted on Jul 05, 2013
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
Actron OBDII (OBD2) scanner stuck in Program Mode.HELP! Model-cp9575
go to magicmechanic online-send him issue-hes a mastertech and will reply
Dec 16, 2013 | 1996 Toyota Corolla
Actron code reads po420 catalyst system ??????
Step 1:
A code P0420 may mean that one or more of the following
has happened:
  • Leaded fuelicon1.png was used where unleaded was called for
  • A damaged or failed oxygen sensor (HO2S)
  • Downstream oxygen sensor (HO2S) wiring damaged or connected improperly
  • The engine coolant temperature sensor is not working properly
  • Damaged or leaking exhaust manifold / catalytic converter / muffler / exhaust pipe
  • Retarded spark timing
  • The oxygen sensors in front and behind the converter are reporting too similar
    of readings
  • Leaking fuel injector or high fuel pressure
  • Cylinder misfire
  • Oil contamination
Step 2:
Some suggested steps for troubleshooting a P0420 error
code include:
  • Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair
    as required.
  • Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor
    in front of the catalytic converter normally has a fluctuating waveform. The
    waveform of the sensor behind the converter should be more steady).
  • Inspect the downstream heated oxygen sensor (HO2S), replace if necessary
  • Replace the catalytic converter
Step 3:
Overall probably the biggest mistake vehicles owners make when they
have a P0420 code is to simply replace an oxygen sensor (H02S). It is
important to do proper diagnosis so you\'re not wasting money replacing
parts unnecessarily.
We strongly recommend that if you need to replace the catalytic
converter that you replace it with an OEM unit. Second choice would be a
high-quality replacement part. There are many stories in our forums
where folks replaced the cat with a cheaper aftermarket one only to have
the code return shortly thereafter.
One thing to note is that many vehicle manufacturers offer a longer warranty
on emissions-related parts. So if you have a newer car but it\'s out of it\'s
bumper-to-bumper warranty, there still may be warranty on this type of problem.
Many manufacturers give a five year, unlimited mileage warranty on these items.
It\'s worth checking into.
Feb 12, 2013 | Actron Code Reader Pocket Scan Plus CP9410
How do I fix an e9 error on my am24-1 model actron air conditioner?
Feb 05, 2011 | Heating & Cooling
Where would you hook up a actron code scanner at inside an nissan infinftf g20 , 1992
You can find codes and download manuals for actron scanners from this website...
http://www.actron.com/product_category.php?id=249
Dec 18, 2010 | Nissan Z Cars & Trucks
Im looking for trouble codes on a 1997 Ford Ranger 1443 came out severity unknown on the obd 2 scanner looking for the actron code book or something can u help ?
P1443 - Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
This site has a free list of trouble codes:
http://www.obd-codes.com/trouble_codes/ford/
May 30, 2010 | Actron Digital Multimeter Tester
How do I reset the ABS light on an 02 Rendozvous?
There are dedicated scanners for resetting the ABS light.
Try Actron Brakescan @
http://www.amazon.com/s/ref=nb_sb_ss_i_0_11?url=search-alias%3Daps&field-keywords=actron+abs+brakescan&x=0&y=0&sprefix=Actron+abs+
Good luck.
May 23, 2010 | 2002 Buick Rendezvous
Actron multimeter does not work
you will have to replace the batteries
Apr 01, 2009 | Actron Digital Multimeter Tester
2000 mazda mpv diagnostic box
There should be an OBD II plug under  the dash on the drivers side. It might have a cover over it so look real close. That actron will give you generic P codes.
Dec 28, 2008 | 2000 Mazda MPV
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
