Question about Darice Narmi Square Frame Two Tone Watch Face for Jewelry Making 1.25" x 1.5"
Remove back how do you take off the back on a narmi round face watch
Broken Armani sign
Yes it can be fixed but may need a jeweller. You cannot take the glass face out on it own, you have to remove the watch back plate and then pull out the watch mechanism. (Once the back plate is off removing the mechanism is not difficult) You then have access to both the inside glass face and the watch face. If you can do this you will need to glue the Armani logo with something like super glue, but not applied directly to watch, too risky. If you have tweezers hold the Armani logo in them. Use a pin and dip it into a small blob of super glue, apply the pin to the back of the logo and then place it on the watch face as quickly as possible and align. Once aligned apply a little pressure with the tweezers on the logo to help adhere, about 5 seconds, leave to dry and then put watch back together. If this all seems to difficult a jeweller can do it in about ten minutes.
Jan 08, 2014 | Watches
How to change the battery replacement on a narmi watch
back pries off, remove old battery, install new, snap caseback on.
Sep 21, 2012 | Darice Narmi Square Frame Two Tone Watch...
Need battery size for blue face round fossil watch
SR920 that is the size of the battery of your watch
Jul 09, 2011 | Fossil Arkitekt watch
If one of the hands have fallen off the face of the watch. can it be repaired by taken the back off or the crystal face? If the crystal face can be removed what is the proper way to remove the crystal
Thank you for contacting FixYa.
Hands are fixed through the back of a watch but due to the delicate nature and complication of this type of repair, it needs to go to a watch repair service tech.
Best regards. Jewel
Sep 18, 2010 | Watches
How do you remove back cover to replace 296 wrist watch battery
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • Sep 14, 2010 | Peugeot Watches
    Zoppinni mother of pearl round watch
    You just need a new pin which is relatively inexpensive. Any jeweler should be able to help you with this.
    Jan 11, 2009 | Zoppini Mother of Pearl Round Face...
    Trying to remove links on a fossil watch w/arrrows pointing out
    Are you pushing the links in the same direction as the arrow is pointing? If so, are you using a tool specifically made for removing watch links? If the answer to both of the above is "yes" then look closely at your watch. The pin will look different on both sides. One side will look like the head of a "screw" and the other will look rounded and just come to a point. You always want to use the watch link remover tool on the ROUNDED end and push the "screw" looking end out. It could be that your watch was assembled w/the pin facing the wrong direction.
    If you appreciate me solving this for you then please rank this solution as "fixya" or at least "helpful", thanks!
    Jan 08, 2009 | Fossil AM3726 Wrist Watch
    Darice Narmi Square Frame Two Tone Watch Face for Jewelry Making 1.25" x 1.5" Logo
    69 people viewed this question
    Top Darice Watches Experts
    Jimmy Accardi
    Are you a Darice Watch Expert? Answer questions, earn points and help others
