Question about Miele Advanta G2170SCVi Dishwasher
Drain pump propeller not spinning
The dishwasher was making a lot of noise when draining. I removed and cleaned the non-return valve, as explained on p. 47 of the manual. The manual says you should spin the drain pump propeller before reinserting the non-return valve to make sure there are no blockages. When I tried, I could not make the propeller make a full turn. I see no debris blocking the pump
  • 3 Answers
SOURCE: Intake/Drain Error
I cleaned out the drain pump and non-return valve on my Miele G658/858 and that fixed the problem. The G841 may have similar parts. It's easy to do. In order: 1. Turn off washer. 2. Remove the triple filter (the basket on the bottom of washer with the little handle. Turn the handle and remove) rinse out and set-aside. 3. Remove the standing water. I used a wet vac to remove the standing water from the bottom of the machine, but you can scoop it out also. 4. Tilt the locking clamp (tilt left) to the side. (this is a metal wire covering the white plastic valve. This valve is to the right of the triple filter basket.) 5. Pull out the non-return valve and rise will under running water. You may have to wiggle the valve a little. Pull straight up and out. 6. The drain pump is beneath the non-return valve. (it has a little plastic propeller, like a paddle wheel, inside) 7. Spin the propeller several times in both directions to make sure it's clear. ( I used the shop vac with a small hose attachment to clear the drain above the propeller compartment) 8. Carefully refit the non-return valve and secure it with the locking clamp. 9. Refit and lock the filter in place.
I haven't had a problem since and my dished are much cleaner- The problem must have been coming on for a long time.
Hope this helps,
Posted on Oct 08, 2008
reverendrave
  • 24 Answers
SOURCE: Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Posted on Sep 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a G1220SC model. F11 shows on the panel,
F11 is a drain error.
Water outlet restricted.
** Check for kink in the drain hose.
** Clean the filter combination. (p.41)
** Clean the non-return valve (check valve) (p. 53)
** Check/clean the drain
Unplug the machine.
Disconnectthe drain where it enters the S bend from the sink. You may find thenozzle into the S bend is blocked. Probe it with a screwdriver andclear the blockage.
Plug in2_bing.gif the machine and re-try.
THIS MANUAL
may not be for your model - however it will give instructions on some of the steps above.
If all checks out - the pump will need replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 04, 2010
  • 3247 Answers
SOURCE: Inlet/Drain light is on. I have cleaned the drain
Is the water inlet turned off by chance? Is there no water at all inside the dishwasher?
Posted on Oct 14, 2010
  • 128 Answers
SOURCE: Miele G892SCB intake/drain light on.
Yes. 1 800 843 7231. follow the prompts to get to the parts department. have your model and serial number handy. They will get you the correct part. If you have any problems getting it in, or it doesnt solve your problem, repost. I will keep an eye out.
Posted on Nov 21, 2010
Testimonial: "thank you, you have been very helpful and have probasbly saved us a new dishwasher."
Our 2 year old Miele dishwasher (G1182/G2182) makes a strange popping/grinding glass noise when draining. We used 1 bottle of Finish Intensive care & clean with no improvement. Any suggestions?
there is a piece of debris in the drain pump. remove the triple filter from the bottom ( the one you are supposed to clean every week to keep debris out of the drain pump) under that filter and to the left hand side you will see the non return valve. squeeze the tab and pull the non return valve out. remove the broken glass or whatever is stuck in the drain pump impeller. replace the non return valve. replace the filter. if you need a picture go to mieleusa.com, and search for your owners manual. it has step by step tutorials on how to free an obstruction from your drain pump.
May 27, 2012 | Miele Dishwashers
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
I have a Miele G2430 and it doesn't drain. I tried the baking soda and vinegar and it doesn't work. Is my pump broken or something? How much will cost to repair it if that's the problem?
Hi Jennyglopez..I do not think your pump is the issue,however you can make this checks.1-Take the filter combination out of the wash cabinet 2-Scoop the water out of the cabinet using a suitable container 3-Press the catch for the non-return valve inwards 4-Lift out the non-return valve and rinse well under running water.5-Remove all foreign objects from then on-return valve and drain pump 6-Carefully replace the non-return valve and secure it with the catch.Ensure that the catch engages correctly.You can also check drain hose &remove any kink in the drainhose.where the drain hose engages under the sink sometime gets clogged.Disengage the pipe & make sure hole in the drainage not clogged.Thanks & goodluck
Aug 18, 2010 | Miele Optima G2430SCi Stainless Steel...
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Meile G653 SCVI dishwasher will not drain
I tried the one below on this site (ie run briefly without the non return valve in place, didn't see objects but perhaps loosened something). So I hope it can help you. Best wishes.
Best Solutionposted on Mar 02, 2010
noavatar_s.gif taurustech
Rank: Guru miele.gif dishwashers_small.png Expert
Rating: 92%, 65 votes
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Apr 03, 2010 | Dishwashers
Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Feb 22, 2010 | Miele 24 in. G653 SCVi Plus Built-In...
Miele incognito not draining
at the bottom left corner their is a manual draining system maybe you need to use that with a bucket.
thats all i can think of unless it still has warranty just trade it in.
Oct 03, 2008 | Miele Novotronic Premier 500 Front Load...
Intake/Drain Error
There is water collected in the inner tray of your unit. Pull out the Miele and take off the drain hose and unplug the unit. Then tilt the dishwasher back 60* and let it drain out all the water. There will be a couple of cups on the floor, but nothing too big that a couple of towles can't handle. Then reconnect everything and start up the unit. It WILL work! It just happened to me and my Miele incognito is now working like a champ again!!
May 21, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
49 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
