Question about Kenmore 75180 Wall/Window Air Conditioner
Drainage leak - Kenmore 75180 Wall/Window Air Conditioner
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking.
If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
May 04, 2014 | Kohler Model 10430: FortĀ® Single-control...
Where are drainage tubes?
If you don't have a sunroof, then your windshield is leaking. There are no other drainage tubes
Aug 26, 2017 | Volkswagen Cars & Trucks
Leaking water on floor, even without water hooked up. Seems to be coming from under the fridge
Your freezer defrost drainage tube may not be routed to the evaporator tray under the refrigerator. If this is the case, humidity condensed from the freezer, then drained down the tube will be dripped onto the floor.
The second theory is that the drainage tube could be blocked. Humidity in the freezer is removed from the air sent to a drainage tray, at the rear of the freezer, which has a drainage tube which carries the water to an evaporation tray at the bottom of the refrigerator unit, on my GE. if the drainage tube is blocked, the water will find another route. Check the drainage tube after you find it. First try inspection. if there is standing water in tray in the freezer, use a flexible wire to clear the tube.
Oct 04, 2010 | GE Profile TPX24PBDCC Side by Side...
Tank leaking air at drainage valve
Valve not shut off. May have trash in it. Tank could have a hole in it.
May 18, 2010 | Air Tools & Compressors
Have a benz 01 ml320, with leaking sunroof drain on
Open up the sunroof and try to unclog the drainage. You will see this from the inside of the ML by opening the whole sunroof and stickin your hear thru. On the drivers side you will see a drainage whole similar to the passenger side. Mine did the same thing and unclogged it with a straw. ljsloan@gmail.com
Apr 27, 2010 | 2007 Mercedes-Benz ML320 CDI
How can i stop my truck from leaking oil so bad?
good day... try to see where its coming from but i believe that its coming from the crank case or your oil pan drainage is a little loose. try to replace the oil pan gasket if it comes from the crank case. tighten the oil drainage if its a little loose. hope this helps. have a nice day
Feb 05, 2010 | 1985 Chevrolet S-10
My Inglis IKU 58660 leaks when it takes water, I belive it leaks as the drainage balls were not put in right place when I put them back after opening. Can I get the picutres showing how should those two...
the leak is probably from the seal that goes on top of the motor inside the dishwasher it needs to be kept wet all the time if it dries out it will get damaged and leak
Dec 31, 2009 | Dishwashers
The coils on the a frame were dirty cleaned them and now i have a leak coming from bottom of afram onto blower motor
Using a vacuum remove all the water from the drainage pan. If the leak is in the drainage pan usue liquid steel, which can be purchased at Wal Mart. If the leak is in the coil. Shut the unit down, allow to dry, then solder using high grade solder, if this doesn't work you may have to contact an AC technican, cost about 65 to 75.
Aug 22, 2009 | Heating & Cooling
Cleaning drainage holes
i think the drainage holes you are reffering to are the ones in the front cowel. You have to remove the wiper arms and the unscrew the cowel to get at the drains.
Dec 11, 2008 | 2002 Dodge Grand Caravan
Kenmore 75180 Wall/Window Air Conditioner Logo
15 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
