Question about Car Audio & Video
Car stereo light out
Everything still works with my car stereo/cd player, but recently the light went out and i cannot see/read any of the display at night. Does anyone know how to fix the problem? Fuse or bulb? Thank you. (Pioneer DEH 42 car stereo.)
  • 1 more comment
  • witsendja Nov 07, 2007
    car steroe works fine no displya light low, slightly legible
  • Anonymous Feb 13, 2008
    yes i have the same problem
  • jaimaga5 Feb 24, 2008
    yea it does not show antthing
download the user manuel here
Posted on Dec 15, 2008
SOURCE: Faceplate display backlight out
I have the same problem with my radio. :( Anybody idea what kind/size of LED to get?
Posted on Dec 29, 2005
SOURCE: Owners Manual Pioneer DEH-9
Posted on Aug 11, 2008
  • 89 Answers
SOURCE: Pioneer automotive stereo cd player error 11
Error 11 is probably the laser...;)
Posted on Sep 26, 2008
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
Posted on Feb 02, 2009
The cd player in my car is A56820, JBL, it will load and eject cf's but not read. any fixes?
Did you get all of the CDs out of the player or are any still
stuck inside the stereo? Its the part about everything working
OK until a disc changed that makes me ask.
If a disc is jammed because it didn't load properly, you won't
be able to get all your discs out.
Oct 23, 2014 | Audio Players & Recorders
2006 Honda Accord Vp Stereo System went out and i have checked every fuse and nothing is working! It started out with the DISPLAY ILLUMINATOR now the whole STEREO went completely Is there any
time to rip it out and fit a after market one ,it sounds like microprocessor has packed up and its cheaper to replace than mess around trying to get it repaired
Apr 27, 2012 | Cars & Trucks
1998 Honda Accord EX stereo/CD player has Code E on the screen... What is the cause of this and what can I do to fix it?
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam and cause the player to display error codes E-01 thru E-07. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 1998 Honda Accord
2004 Solara: My 2004 Solara stereo recently stopped working com...
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Nov 20, 2017 | 2004 Toyota Solara
My car stereo stopped working. No light display. The display light went out first. The following year the radio, CD and cassette player stopped working.
Check radio fuse at the fuse block. OR if possible determine if you have
12 volts going to the radio. If so i would say the unit is toast.
These days it's hard to fix something for cheaper than it is to buy new.
Aug 08, 2009 | Car Audio & Video
Cd player has no lights or display
lcd reader on face plate is bad
Jun 23, 2009 | Sony CDX-M610 CD Player
Car radio is not reading any cds or dvd
You need to disasemble the stereo and clean the laser lens manually
Jun 23, 2009 | Naxa Electronics NX-662 CD Player
All the dash display lights suddenly went out
Modern CAN-bus electronics can do some very strange things when the battery voltage is very low and your description of events matches almost exactly with those experienced by a friend shortly before he needed to replace his car battery.
My own experience tells me some stereos should not be fitted to some cars or a discharged battery will result (unless the wiring is suitably modified). It is important to read the instructions - carefully!
I strongly suggest you have your battery and charging system tested and the stereo removed until it is discovered to be compatible...
Jun 12, 2017 | 2001 Volkswagen Golf
Siemans VDO CDR500 Audio player for Vauxhall Astra 1999
Switch off the stereo so that the date and time show on dash. Press and hold the volume button and the AS button together for about 5 seconds. It should now ask you to input the code. Do this by using the numbers 1 2 3 & 4 on the stereo. When the code is entered, press and hold the AS button on its own and wallah, your cd player is up and running
Jul 16, 2008 | Car Audio & Video
XDM6825 Not Playing MP3s in Stereo
if you have a FM MODULATOR installed too,some ones no transmiting in stereo mode, try changeit
Feb 14, 2007 | Dual XDM6825 CD/MP3/WMA Player
Car Audio & Video Logo
216 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
