Hi I have bought a brand new, in the box Asus ET1612IUTS. when I switched it on for the first time I got the following messgae, ' boot device not found, insert a boot disk and press any key.' The only thing that came with the product was a support dvd but this system does not haved a cd/dvd port ( that I can sse anyway), a quick start guide (which basically says switch it on!) and the warranty booklet. Can you help? What should I do?
SOURCE: Broadcom UNDI PXE-2.1 v10.0.9
The Broadcom PXE looks for a boot device/files from a network source if the network cable is't plugged in then you get the PXE-E61: Media test failure check cable, you can turn this off in the bios, when this doesn't find any boot information it moves onto the next boot device which is defined in the bios, usally the dvd drive then the HD. If this is a Altos server you have bought they are not supplied with an OS so it wont boot from the HD to begin with, if you already had a OS installed and it wont boot then there is something wrong with with the HD or the connectors or posibly the boot sectors are corrupted, if the device is making th tak tak noise the it is having trouble reading te device.
Posted on Aug 12, 2008
freetek
  • 5568 Answers
SOURCE: Aspire 5315, no bootable device, PXE-E61 media test failure,
With any standard laptop (your Aspire included) the default boot disk should be set to drive C:
If the system is not finding drive C:, the boot sector may be damage or the drive may have failed completely.
Depending on your operating system (probably Win XP for this one) you can make a boot disk on a friend's optical drive and change the boot sequence in the BIOS setup to your optical drive. Just make sure the disk you've made is compatible with the drive in your Aspire; such as CD - DVD+-, etc.
Once you can get some kind of prompt, either from a basic Desktop or just E:\ from your boot CD, try typing in "C:" (without the quotes) to see if it is accessible. If not, the drive may be bad.
If the drive is still readable, you have more work to do to restore the damaged boot sector.
Posted on Mar 21, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
  • 10 Answers
SOURCE: I have an ASUS A6000 laptop which has worked fine
Hi, you'll have to go to bios/Cmos settings& set the bootable media as your CD/DVD rom drive name & you can try to recover it.
Regards
Kunal
Posted on Jul 14, 2009
  • 31 Answers
SOURCE: On my asus eee pc
It sounds like you have a bad hard drive. Make sure you don't have any CD/DVDs in the drive if that model has one and you don't have any USB devices plugged in at boot.
Posted on Oct 18, 2010
Dcd985 reverse switch won't work
The switch (PN: N089938) for your drill costs between $75 & $80, so:
If by "brand new, just out of the box" you mean you just bought it, bring it back to where you got it and exchange it or get your money back.
If by "brand new, just out of the box" you mean you bought it, it sat somewhere for some time and you're just now using it, check to see if it's still under warranty so you can get it fixed through that.
If it's out of warranty, you'll have to buy a switch to fix it. They're available on sites like www.ereplacementparts.com.
Feb 21, 2013 | Dewalt DC925 Cordless Drill
Brand new Asus eepc with broken power socket- how can this happen and is this repairable?
HI
If this is a brand new machine then if possible take it back to where you bought it from and they should either replace or repair it
If you bought it online phone or email them explaining what has happened
go for it
Nov 18, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How do i format a brand new hard drive and load the OS on it?
Hi, formattin option is in the os installation disc. insert the os disc and go to the boot menu and set the first boot device as cd rom and save the proces and restart the system.then press any key to go into the installation and follow the instructions .to go to into the boot menu option as soon as u restart the system press f12 continuously........ Best wishes
regards, sathyamoorthy
Nov 18, 2010 | Acer Aspire 5315 Notebook
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
Display driver problem
Hi there ;
hey can u boot into the safe mode and go to the system restore from there and restore it just before the time that it messed up if not please let me know there is still things that we can do
best regards mike
Mar 07, 2009 | ASUS Computers & Internet
Asus 1000 freezes after 2g ram upgrade
Go into bios and make sure mem is set to auto find ,might help
Feb 24, 2009 | ASUS Eee PC 1000 Notebook
Asus P5N-E SLI Mobo will not boot or post.
Hi bart, please re-check you're memory. See page 1-17 in you're user manual. (Read everything)!
You're Asus board can not use 184-pin DDR DIMM's.
Also check the QVL list for supported memory page's 1-18 & 1-19.
I did not see Corsair on either page.
You're board can only use 240-pin DDR2 memory. Please read the "Notes" at the top of page 1-18.
If everything (Regarding memory) is within the Asus specifications than clear the cmos/bios & re-boot again. If you're system still does not boot than remove one DIMM & try again.
Asus warrants their boards for three years. Call Asus tech at
1-812-282-2787 EST, IL 8:00AM to 5:00PM. The call is on you but the service is free. It's worth every dime.
Good Luck & Kind Regards.
Would you be kind enough to let me know what Asus suggested? (If it comes to that).
Mike
May 15, 2008 | ASUS P5NSLI (0610839134670) Motherboard
Help!
Have you installed RAM? If not the machine will not boot. You may also need to enter the BIOS setup to set the CPU and DRAM voltages and multiplyers etc. Follow the instructions in the manual for setting up the CPU info in the BIOS. Are you sure your PSU has enough guts to run the setup? Many times have i seen setups fail because a cheap power supply has been overstretched.
Jun 14, 2007 | ASUS P5B Deluxe/WiFi-AP (P5B DELUXE /WIFI...
Brand new
first go full bare-bones...only video, keyboard,mouse turned on in BIOS. then re-install windows. if still no good repeat above steps except to add this step just before windows: run fdisk to re-partition the drive and then run format using the svs switch...then re-windows. if successful, then turn on system restore to create a restore point and re-boot before any new devices are added to system
May 24, 2007 | Foxconn 865M01-G-6LS Motherboard
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
