Question about Garden
Toro timecutter z5000
Cracked engine block
kel1guy2002
  • 3740 Answers
SOURCE: need manual to see what size bolt is that holds on
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Posted on Apr 27, 2010
  • 15941 Answers
SOURCE: I have a Toro Z14-38
There is very little likelyhood that you will be able to get the manual that you want.
First TORO has proprietary information on their products.
Second is the fact that you are agreeing to only pay 4 dollars for something like that.
The only other thing that you can do is look in the US patents database to see what you can find.
Posted on Nov 27, 2010
  • 6468 Answers
SOURCE: Toro Z5000 won't move
did the belt break or fall off? are the trans release levers pulled out ?the ones you release to push it around
Posted on Apr 15, 2012
  • 9 Answers
SOURCE: toro timecutter MX 5060 cranks fine with choke on when you turn choke off the mower dies what can cause this
dirty carburetor need to clean
Posted on Jul 23, 2012
allen273
  • 27 Answers
SOURCE: Toro 42 timecutter
Bad starter motor. replace starter motor.
Posted on Aug 02, 2012
I have a toro Timecutter z5000. when I pull the handle to turn right it does not respond. what could be causing the problem,
linkage could be off, brake could be stuck on, belt could be off, hydro pump could be bad. take a pick.
Nov 22, 2016 | Toro Garden
Loss of power and muffler turns bright red just after a few min. of running ?
Most muffles have a small screen on them where the outlet is. It's called a Fire or Spark arrester. they clog. when they do clog it generally causes lack of RPM's and a build up of heat.
Jun 02, 2015 | Toro 110-6892 Timecutter Z5000, Z5020,...
Toro clutch removal
PTO clutch removal.
remove the crankshaft bolt and be prepared for the clutch to fall
if it doesn't get a soft faced mallet and tap on it
no, get some pb blaster and let is soak for a day or two
then tap a little harder
if still no you will need an air hammer
Aug 14, 2014 | Toro 110-6892 Timecutter Z5000, Z5020,...
Toro troubleshooting
I have a toro timecutter z5000, after disengaging the drive in order to hand push the mower it doesn't go back into drive mode. what can the problem be?
Jan 02, 2014 | Garden
Toro z5000 bogs to almost stalling out with minimal load
I would purchase a compression tester from auto parts store and check compression.
Oct 19, 2013 | Toro 110-6892 Timecutter Z5000, Z5020,...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
