Question about Frigidaire Heating & Cooling
No Drain Holes
I just bought four Frigidaire 6000 BTU air conditioners, Model #LRA067AT7. However, none of them have drain holes in the back and water is pooling inside the air conditioner and the fan blades are hitting it. Is there some way I can drill a hole in the back to allow the water to drain? If so, where should I put the hole so I don't accidentally hit the coils?
SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
Posted on Jun 23, 2009
rogrrabbit
  • 986 Answers
SOURCE: Damaged
Wow major bo bo. You need to have the tube/ coil whatever you hit replaced. then recharge it with freon. Call a profesional.
Posted on May 21, 2010
  • 2468 Answers
SOURCE: Does Whirlpool air conditioner #
theres one near the back side on the outside part,they get plugged with bugs,leaves,debris,etc.,when its shut off look underneath and there is a drain hole on the bottom or on the rear ledge on either corner or both rear outside corners,make sure the unit has a slope toward the outside so most of the water drains there too,you can use a short piece of wire to clear these drain holes,if they are dirty enough you may need to unplug the unit and use a garden hose to dilute the debris so it flows out the drain holes
Posted on Aug 04, 2010
  • 5 Answers
SOURCE: I have a Kenmore Air Conditioner Model No.
Make sure the filter and coil behind the filter are not dirty (I am sure you did that already) as this would cause icing and excess water build up. There may be a steel or plastic plug in the bottom rear of the unit. If not, I have drilled a hole in the very rear right or left side of some to help drain the water, but you need to be sure that nothing, nothing at all is on the otherside where you drill (No wires, no tubing, no compressor, etc,) as you will damage the unit. If it is a newer unit under warranty call the manufacturer as newer units disipate the water in the exhaust air and it may be malfunctioning or it may just be extremely humid ouside and the unit is struggling to disipate the water.
Posted on Aug 07, 2010
  • 4736 Answers
SOURCE: why isn't there drain holes in bottom of
It shouldn't be a problem if you drilled the hole near the rear, outer edge of the drip pan and didn't accidentally pierce any of the mechanical above it. Also, be sure the rear of the unit is tilted down at least 1/4" to 1/2", so water will flow to it. Check the drain hole periodically, as they will become clogged over time.
Thanks for choosing FixYa.
Posted on Jul 23, 2011
Where is the condensate line on a Frigidaire wall air conditioner?
There is sometimes a plastic hose between the evaporator and condenser side on the bottom of the case. Other models simply have holes in the metal for condensate to drain into the condenser side . Make sure there is no obstruction to the hose or holes. If you find none, then check the level of the unit. It MUST be slanted so the back of the unit is lower than the front.
Sep 19, 2015 | Frigidaire Heating & Cooling
Drain Hole Air Condition
No. You have to make sure when you install it into the window that the end (back) that is outside is slightly lower than the (front) end that goes into the window. That way it drains to the back, over the lip and onto the ground. If you have it at an angle and you are still having a problem then slightly increase the angle. If you drill a hole in the bottom of the unit be careful not to hit any coils or lines. Also make sure you do it at the back of the unit. Again watch the coils. If you hit the coils than you will lose all of the freon and the unit won't cool at all until repaired.
Sep 17, 2014 | Frigidaire 10000 Btu Window Air...
What is the starfoam for in my airconditionar for?
Hey friend, thanks for your inquiry!
The sytrofoam inside the air conditioner is part of the duct work and it also helps to hold colder temperatures. The new air conditioners do not have drain holes but instead recycle the water inside your appliance to help cool the internal components. I hope this information is helpful. -Matt
Aug 30, 2014 | Frigidaire Heating & Cooling
Where is the drainage hole on this unit?
Some don't have drain holes.You can make a hole by drilling the chassis. Some just have to be installed with a slight lean to the back so they drain properly.
Jul 12, 2014 | Haier ESA408KE 8,000 BTU 10.8 EER Fixed...
Bought the Frigidaire 6000 BTU Window Room Air Conditioner LRA067AT7 6 months ago and it worked fine until last week, It will not turn on although plugged in and the wall outlet is good. Is there an auto...
Good Morning Luca,
I understand your Frigidaire air conditioner, model# LRA067AT7, will not turn on. I also see that the wall outlet is good, so you are wondering if there is an automatic shut off if the filter has not been cleaned. Your air conditioner does not have an automatic shut off, if the filter has not been cleaned. Please start by cleaning the filter. You can do this easily with the following instructions:
The air filter should be checked at least once a month to see if cleaning is necessary. Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
    1)Push the vent handle to the Vent Closed position (where applicable).
    2)Open the front panel.
    3)Grasp the filter by the center and pull up and out.
    4)Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing
    5)Or instead of washing, you may vacuum the filter clean.
    Also, be sure your air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. Do not run your air conditioner without outside protective cover in place. This could result in mechanical damage within your air conditioner. Do not use an extension cord or an adapter plug.
    The power supply cord contains a current device that senses damage to the power cord. To test
    your power supply cord do the following:
      1)Plug in your Air Conditioner.
      2)The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
      3)Press the RESET button. Again you will notice a click as the button engages.
      4)The power supply cord is now supplying electricity to the unit. 4)
      I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
      -Best Regards-
      WP
Jul 09, 2014 | Frigidaire 6000 BTU Window Room Air...
My frigidaire air conditioner LRA067AT7 won't cool
The thermostat isn't turning on the compressor. Check it out first. If it seems ok then check the wires going to the compressor. One of the 2 places will be the trouble .
Feb 05, 2014 | Frigidaire 6000 BTU Window Room Air...
How can i fix this problem
it sounds like it might be cloged up it happend to mine i had to put 2 small holes in the bottom out side and get all the leavs out of it then i had to clean the filter
Jul 11, 2012 | Danby 6000 BTU Window Air-Conditioner 10.7...
I have a 6000 btu window unit. I was wanting to know how the unit drains the water. where does the water come out of the unit at? I could not find a drain hole.
No drain holes on most units that size
The water gets from the front evaporator thru
a small hole you can not see
Then it finds it's way to the outside or back on the
bottom metal pan
It is evaporated by the condensor fan
It may drain out over the rear pan lip, if
it gets alot, but no drain hole is necessary
You can angle the unit down at the outside or
rear & you can drill a small hole, but it uses the water
to cool the condenser
Aug 04, 2011 | Haier HWR08XC7 Air Conditioner
My frigidaire wall unit ac is drippijng water inside of apartment. i have used a level when it is out of the wall and it shows ac is tilted correctly to the b ack but when i put it in the wall the level...
The drain holes in the bacl are plugged with dirt...
pull the A/C out and check for the blockage and remove it so that the unit will drain properly.
The drain holes are usually in the back corners...
heatman101
Sep 24, 2010 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
