Question about Epson Stylus Photo 1290S InkJet Printer
Stylus Photo 1290
My printer keeps coming up with thr following error in the status monitor: "Installed Ink Cartridge Not Recognized." "Replace the black ink cartridge." I Have replaced the cartridge Several times with NEW GENUINE epson cartridges, it does not seem to be solving the problem. I Have also replaced the PRINTHEAD, PRINTHEAD CABLE it made no difference. I tested the MAIN BOARD on another machine and it works fine in that one. Has anyone else ever had this problem and maybe found a solution. Thanks.
  • edward richmond Jan 31, 2009
    I have pink images coming out of my printer.can you help
    many thanks ed
    I have pink prints coming out of my printer.Can someone help
    many thanks ed
    Problem Solver:
  • 8 Answers
Ratt, Please uninstall all related Epson Stylus Photo 1290 softwares, drivers etc. and also clean registry by using any registry cleaner. After going through all this, restart your OS and reinstall your Stylus Photo 1290. If this doesn't solve your problems, then please try this. Steps: 1) Backup all your important document from where you've install your OS (e.g. c:\) 2) Format the drive where your OS is installed (e.g. c:\) 3) Re-install your OS in fresh. 4) After completing your OS installation, install your printer..... GOOD LUCK !!!
Posted on Aug 28, 2007
How to reset ink counter for a epson R230
The page counter cannot be set back to 0.
The ink levels on your computer is automatically checked and displayed through the Status Monitor
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Sep 27, 2010 | Epson STYLUS R230 InkJet Photo Printer
Unable to operate epson stylus office B40W Vista due to blockage of printer by epson status Monitor 3
EPSON Status Monitor 3 displays detailed information regarding the following:
1.Current Status:
2.Ink Levels:
3.Ink Cartridge Information
Please follow the error message prompt, seems like that you need to replace the cartridge for the printer.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
Sep 26, 2010 | Computers & Internet
How do I know WHICH of the ink cartridges is out?
I found this on the Epson Web Site. If you find this information helpful, pls rate me.
You can download the Reference Guide with pictures and all.
http://files.support.epson.com/htmldocs/r220__/r220__rf/index.htm
Windows
You can check the amount of ink remaining in the ink cartridges using EPSON Status Monitor 3 or the progress meter. Refer to the sections below for details.
EPSON Status Monitor 3 Access EPSON Status Monitor 3 in one of the following ways.
  • Double-click the printer-shaped shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar, see the section below.
    font26.gif See Monitoring Preferences
  • Open the printer software, click the Maintenance tab, then click the EPSON Status Monitor 3 button.
A graphic displays the remaining amount of ink.
Pls rate me. Thanks and Good Luck.....
Feb 09, 2010 | Epson Stylus Photo R220 InkJet Printer
Green and red lights on solidly, error message saying 'cartridge not recognized' even when it is a brand new Epson cartridge! Tried a reset but it doesn't make any difference
When you installed the cartridge, did you check for any protective tape on the cartridge at the bottom. This is a common missed item in the installation process. If there is tape on it, check instructions and remove it. The cartridge will not work otherwise.
Feb 02, 2010 | Epson Stylus Photo 1290 InkJet Printer
Espson Stylus D92 not recognising cartridge change
Do replacement procedure, follow How to.. on status monitor. When asked to replace ink tank, unplug all ink tanks, and plug only cyan ink tank. Next....next.. Finish. See status monitor. Is cyan recognized (Not cross sign)? If yes, repeat procedure, without unplugging, plug others 1 by 1.
If no, check for chip connector (for cyan) at carriage, or try to use another cyan ink tank.
Sep 20, 2009 | Epson Office Equipment & Supplies
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Red lights flashing. I dont think the ink is out and i did try taking them out following the instructions and put the same ones back in but it still won't print and the light is still flashing, will it...
Printer wouldn't print if red light flashing. Check status monitor for detail? Are some ink not recognized? Do replacement procedure from status monitor on "How to...". Unplug all ink tank. Plug only one ink tank . See status monitor. Is ink tank recognized. repeat procedure, and add ink tank 1 by 1. How about status monitor then?
Jul 09, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Epson stylus photo 1290 printing black splodges
Joy:
Once more have the printer to perform the ink nozzles cleaning.
If you are using a ontinuos ink system, place it at the same level than that of the printer.
With the printer in the "replace carrtidge position", put it OFF and by hand, clean the place at which the cartridge rest.
Good luck and merry christmas
emiliosan
Dec 22, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson stylus photo 1290 'bk ink cartridge not installed properly'
Ameter:
Remove the black ink cartridge.
Check the place where the new cartridge should go. Check for a round small piece like a bushing or a little piece of pipe, stuck at the ink entrance of the printing head. This is a piece from the old cartridge, that sometimes gets loose and remains in place,and when the new one is placed, it doesnot go down to the right place to make contact with the electric connectors in the printing head.
If nothing solves...reinstall the printer drivers.
Good luck and Merry Christmas
Emiliosan
Dec 09, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson C60 Stylus Status Monitor Does Not Work On Windows Vista
I ve been having the same problem with my Epson 1290 and Windows Vista! It works fine but I cant get the status info on my ink levels. Its so annoying when u run out of ink the LED on the printer goes on but you dont know whick cartridges to replace! I hope Microsoft and Epson get this sorted out because it so annoying and I end up spending more money on inks than needed! I read someone had similar problem, installed the 1290 M driver (via Vistas set drivers) but it didnt work for me!
any other suggestions?
Apr 18, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Photo 1290S InkJet Printer Logo
248 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
