Question about Yardman Garden
How do i adjust belt on self propelled mower yardman 12A-526L062
How do y ajust m'y clutch It slipery on hill
Posted on Aug 23, 2014
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
  • 77 Answers
SOURCE: starts but when chock goes off stops running
OK take and check this. A lot of the honda engines,especially push mowers,tillers and pressure washers,they put a type of coating inside the gas tank. The bad thing about this type of coating is it has a tendency to peal and wash into the carb. I would look inside the tank to see if there is any debris. I would also clamp off the fuel line and take out the bolt that holds the fuel bowl on and catch the fuel that drains out in a clean tray. If it looks dirty,pull the carb and clean it,it should fix it.
Posted on Aug 09, 2009
  • 16 Answers
SOURCE: I have a yardman 12A-26M7001 self propelled lawn
Did you leave fuel in it all winter ? If you did it probably went stale.Try draining the fuel out and replacing it with fresh fuel.If it still wont start the fuel left in it may have formed a varnish build up in the carburator and may need to be removed and cleaned. Also check for spark and a good spark plug.Hope this helps you out. Good luck.
Posted on Sep 18, 2010
SOURCE: I bought a Yardman 21" Series 560 self-propelled
what is the plug type and number and gap for yardman 560 21" 6.5
Posted on Mar 20, 2011
What would cause a troybilt self propelled mower 12a-466m011front wheels to lock up when pulling back? Also why would this continue when mower is off?
There could be several things. Have you recently changed the belt? Was it an OEM belt? i have seen loose trannys cock in such a way as to put the belt in a bind and not let it slip when reversing. More likely is that there are dogs on the wheels and one or both aren\'t releasing.
May 31, 2014 | Troy Bilt 5.5hp Self Propelled Mower
What are the steps to start mower.
I could not locate your exact model for a manual. This machine's manual is very similar. Please read the operating and "How To Start" instructions inside the manual. They can tell you better than I.
http://lawnandgarden.manualsonline.com/manuals/mfg/yardman/120874r.html?idRes=11171312
Sep 11, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Hi I need a parts and repair manual for the yardman 12a-978q452 mower , I can not finded on line.
I know this was more than a year ago, but I just got one second hand and had to find the same thing. It's made by MTD in Canada. Here's the site to find it. They don't have the manual for the exact same model number, but I've gone through it enough to know it'll work. http://www.mtdproducts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10500&catalogId=20500&langId=-1
May 06, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
How do you adjust the drive cable on a troybilt self pro pelled md# 12A-446A711?????
Unfortunately, you cannot adjust it. If you have an extra space to move it lower than it was on the handle you can do that. You might have to get a new cable. Or the belt may need to be replaced. Do you hear a grinding noise when you try to engage the self propel? If so the transmission may have gone out. The most common problem is that the belt has jumped off from where it needs to be and it is no longer turning. To check to see if the belt is off, you will need to put the mower on its' side, the side with the oil level check is the correct one. You will need to loosen the cover over the drive belt. This is done by loosening one or two bolts that hold it in place.The bolts should have 3/8 hex heads. You may have to maneuver the cover a bit to see if the belt is in place. If the belt has jumped above the pulley for the self propel then you will have to install a new belt.
Mar 26, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I bought a Yardman 21" Series 560 self-propelled mower used and the belt was missing. What belt does it take? The manual says 754-04080, but I'm looking for a locally available V-belt. Thank you.
Are you sure the belt part number is not 754-04088?
That is a 33 inch belt. I do not know if you need the 1/2 inch or 3/8 inch wide belt. Pulley size would be the key for belt width. I think it is 1/2. Any local source automotive parts or Lawn Mower supply will have this belt in stock. 1/2 x 33 or 2L 33
If by chance I got the belt part number wrong, (I don't think so) just respond here and we can keep searching for your belt.
Thanks for using Fixya.
Kelly
Jun 17, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
93 people viewed this question
Top Yardman Garden Experts
Dennis Key
Dennis Key
Jerry Kramer
Jerry Kramer
Daryl Gleaton
Are you a Yardman Garden Expert? Answer questions, earn points and help others
