Epson xp400 spitting out ink on edge of envelope
  • 390 Answers
SOURCE: MP460 printer--problem w/ envelopes
You seem to have clogged nozzles/printhead. Take out cartridges, do a thorough clean down where cartridges sit, the printhead, even the roller as well. Run your printers own cleaning maintenance before you do it manually with cleaning solution. Problem should be gone when you reinsert cartridges. Don't froget to reset ink levels and cartridges. good luck!!!
Posted on Aug 31, 2007
jackboy
  • 2985 Answers
SOURCE: Ink smudging
Run a cleaning sheet through the printer- absorbant papaer- blotting paper. If this machine has had a lot of service it may be your waste tank is filling up and leaking out - have you had a service warning yet?
Posted on Sep 21, 2007
  • 214 Answers
SOURCE: Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Posted on Apr 25, 2009
adnanbhatti
  • 1188 Answers
SOURCE: Epson Stylus C86 smearing
Your printer has ink build up inside it. This comes from cleaning cartridges and builds-up steadily over time. Remove top cover. Wet a cotton swab with isopropyl alcohol (available at drug stores) and clean the inside. use a cotton bud where the swab gets entangled.
Posted on Aug 07, 2009
  • 544 Answers
SOURCE: When I send envelopes to
There is a possibllity that your ink cartridge at the printing nozzle has excessive ink.
Remove the ink cartridge and clean the face and edges around the ink nozzle
with a swab or paper towel.
Posted on Mar 11, 2011
EPSON XP400 SCANNED IMAGE FADED B&W OR COLOR
try to reinstall drivers or try to scan connected to other pc, if problem remains, scanner is done
Feb 02, 2015 | Epson Office Equipment & Supplies
Print photo using XP400 from iPhone
If it's an Epson xp400 it is compatible with an Iphone using Airprint. About AirPrint Apple Support
Jan 02, 2015 | Epson Xp-400 Small In One
When I send envelopes to the printer, the printer is leaving ink marks on the edges of the envelopes
Mar 10, 2011 | Office Equipment & Supplies
Aug 07, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Ink smudging
Sep 16, 2007 | Epson Stylus RX500 All-In-One InkJet...
Paper / Envelope feed
Envelopes Follow the steps below to load envelopes into this product. Lower the output tray and slide out the extension. Move the feeder guard towards you. While holding down its locking tab, slide the left edge guide so that the distance between the two edge guides is slightly wider than the width of your envelopes. Load envelopes short edge first with the flap side down, as shown in the illustration. Use the line on the feeder guard as the indicator when loading envelope. The right edge of envelope is aligned with the line on the feeder guard. Set the feeder guard back. Note: * The folding quality and thickness of envelopes vary widely. If the total thickness of the stack of envelopes exceeds 10 mm, press each envelope in the stack flat before loading. If print quality declines when a stack of envelopes is loaded, load one envelope at a time. * Do not use envelopes that are curled or folded. * Flatten the envelope flaps before loading. * Avoid using envelopes that are too thin as they may curl during printing. Extract from CX3200 user manual
Sep 25, 2006 | Epson Stylus CX3200 All-In-One InkJet...
42 people viewed this question
k24674
jasbo
jasbo
