I need a motor for a wispercool rw3000a 1/8 hp 115v
Has a short
  • 1388 Answers
SOURCE: rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Posted on Dec 14, 2008
pierre1811
  • 144 Answers
SOURCE: Not sure what blower motor to get for my furnace
The real relevant info is 1/2 hp, 1050 rpm, 115 vac, 1/2 inch shaft. Bring that info to any HVAC supply, any appliance parts, Graingers etc. and they should be able to match it up. I just went to the Graingers site and you can order one for $87.50 plus shipping. lease give me a good rating for getting this info for you. Thanks.
Posted on Jan 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Need to hook-up pond
We need to know what wires you have as far as connections to the motor AND the switch. I.e. Red white black green and ______?
Is the switch resistive or just a 2 position (high/ low) 15 Amp switch?
We also need to know how the the terminals on the motor board are labeled. i.e T1, L1, T2, L2. T3, T4 etc and ground. L1 Black L2 White for high speed Green for gorund. The other 2 colors will be for the slower speed winding.
Experimenting with electricity can be costly and VERY dangerous. I would do continutiy checks on the motor windings across L1 and L2 or T1 and T2 and the same for the 2nd winding terminals. Then do the same continuity check from the power wires through the switch and verify the winding resistance across the 2 power leads in BOTH switch positions BEFORE applying power.
Most reputable pump manufacturing companies have the winding terminals on the label or included with the pump with a basic wiring diagram.
FYI you can... use a gate valve for controlling output flow from the pump and run the pump at one speed as an alternative.
I am just being honest here.. without either a wiring diagram of your pump and switch assy it is difficult to pass "safe and sound" advice to you.
Thanks for using FixYa.
Kelly
Posted on Apr 07, 2010
  • 990 Answers
SOURCE: Removal of Aqua-Flo pump from motor
You will need to pull the front of the pump off then unscrew the impeller. The impeller will be set on the shaft and will take some force to break free. Hold ing the back of the shaft and using water pump pliers on the face of the impeller will usually work but sometimes I will wedge a screwdriver in the fin of the impeller and hit it sharply (not hard) with a hammer to break it free. Then the housing will just pull free of the motor. When replaceing, the impeller just goes on hand tight. Hope this helps and good luck.
Posted on Apr 16, 2010
Devious1969
  • 76 Answers
SOURCE: I need a 1/8hp 115v 1075 2sp swamp cooler motor
Unless you can find an HVAC shop with a NOS motor for this unit you will not find a drop in replacement. Even if you do get lucky and find a NOS motor be prepared to pay nearly as much for it as you would a whole new evap cooler.
That said, there are motors out there that will work, but you're going to have to make them fit with custom mounts.
It's still a little spendy, especially if you want two speeds like the original motor had, but you can get out for $80 or less if you're willing to settle for one speed (on/off).
boatandrvaccessories.com has a "Packard 40066" compressor motor for $69 plus $13 shipping. It may work but has only one speed.
Basically what you're looking for is a "48 frame", 1/8 hp, direct drive, 110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to give you flexability when mounting), "totally enclosed" or "open drip-proof" housing (NOT "open"). Rotation can be either CW or CCW as you can mount the motor on either side of the housing and some motors are reversable. If you've got the skill to custom make some mounts then you can probably fudge some of these specs. The ones you can't change are the 1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assembly simply can't be made to go much faster in that housing and if you try you will overheat the motor and burn it out very quickly (trust me on this one!). Most of the cheap motors I've found are 208-230v and I just don't see the point in having a small 220v PORTABLE evap cooler, that's just dumb.
After a LOT of online research I've found the following motors that would be a suitable replacement, with all the above mentioned specifications. I'm sure there are more, but cross referencing this information for someone not in the business is tricky and time consuming.
AdobeAir 1/8 HP 115V Motor for Adobe MMB10A RF031095 $116.66
http://www.comfortgurus.com/product_info.php/cPath/25_142/products_id/7451
Emerson 4856 (k055srj4796722b) (www.emersonmotors.com)
A.O. Smith 136A (UH1036NB) (www.aosmithmotors.com)
Magnetek 136 (now owned by A.O. Smith - www.aosmithmotors.com)
Fasco D733 or D261 (fasco.com)
Marathon X924 (www.marathonelectric.com)
AdobeAir RK232A check acehardwaresuperstore.com
Emerson K55HXKZT-9867
Grainger.com is a good resource but they are expensive.
The motors listed are suitable replacements, but have only one speed, "ON" or "High".
Packard 40066 - 115v 1075rpm $69 - SINGLE SPEED
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Good reading for selecting a replacement motor:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=13100
I suppose that if you found a smoking deal on eBay for an "Open" type motor you could try it, but I doubt it would last long and make damn sure that ****** is grounded well.
Posted on Sep 06, 2010
Changeing 115volt to 230 volt
Most power Flo pumps run above ground pools and run on 115v only.You can look at the wiring diagram on the motor label to see if it is convertible, it will show wiring configurations and amps for both 115v and 230v. If not, it is a 115v motor only.
Sep 11, 2013 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Blower motor on furnace not working?
if motor is very hot it will need to be replaced
Nov 08, 2012 | Emerson Lennox 1/3 Hp Blower Motor 115v...
How can I run my aosmith 1hp pool motor on 115v?
LOOK ON THE MOTOR LABEL IT WILL HAVE A PICTURE ON HOW TO CHANGE IT, OR TAKE THE COVER OFF THE BACK AND LOOK CLOSE YOU WILL SEE HOW TO CHANGE IT.. jay the pool pump motor repair guy in longwood Florida 32750 .. BEST TO RUN PUMP ON HIGH VOLTAGE , IT WILL RUN COOLER AND LAST LONGER AND CHEAPER TO RUN $$$
Sep 21, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
IS MY WATER PUMP MOTOR BURNED?
The easiest way to be sure is to meter the cord and see if you have 5-10 ohms across the lines and infinite resistance on each to the ground prong. You are better served to use a high output voltage tester as compared to a small hand-held 9 volt meter for testing grounds. It is likley the motor is shot though and the unit will need to be replaced.
Oct 01, 2009 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
My motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Rewiring mootor from 230v down to 115v
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
