Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Replaced Convergence Board...then...Blue shawdow appears
I am now really frustrated! I just purchased and replaced the convergence board which was purchased from Baldwin Electronics. My tv worked for about a minute. Then...a horrible blue and shaky shadow overtook the screen. What could be the problem? Should I get a new convergence board or refund since it didn't give me the results I was looking for? Thanks...SH
  • STEVE HILL Sep 12, 2007
    I received a new convergence board. It fixed the blue shadow; however, I am back to the red being shadow. This was my original problem; however, it looks a little different. The top left portion of the screen is really distorted when trying to manually adjust the convergence. It looks almost like it is slanted. It obviously "throws" off the red alignment. Please provide information in regards to the problem, and also...how much will it cost to fix with a repairman? Should I just go ahead and buy a $1400 LCD screen?
    President:
  • 3,130 Answers
Maybe the new board was bad, or the B+ that feeds the convergence board is bad., This is where experience comes to play I'm afraid. Good Luck.
Posted on Aug 29, 2007
  • Larry  Dillon
    Larry Dillon Sep 12, 2007
    The new board sounds like it is still No Good. The IC's on the new board, do they have the word Sanyo on them? If not, that is most likely the problem.
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Blue gun adjustment does not move blue line in menu convergence function. Any way to adjust or fix?
No.Fix.Tv have dead parts on the tv convergence board.Tv colors lines R,G,B mis alignment,can't move any colors lines.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead on the tv convergence board.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Toshiba 61H70 61" Rear Projection...
Magic focus blue is fine, green and red are really blurry, tv picture is almost black and white. all bulbs are on.
Tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the convergence board,to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 13, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Model 55PP935217 multiple convergence mode, the blue colored + is pulsing after IC chips #7044 and #7045 were properly replaced and resistors (12) were good. When single convergence mode is selected, the...
I understand your frustrations, and if you did the work yourself you can feel really bad. In this case if you really want to save this TV, I would suggest you visit Union Electronics. And purchase a reworked replacement board. In many cases this is the best route to go and the price is reasonable. Call them at 1 800 648 6657. I have had very good luck with this company! And these boards are guaranteed, ask for the lenghth allowed. Have your TV model # and tell them you are looking for the convergence board. Thanks for asking!
Aug 08, 2010 | Philips 55PP9352 55" Projection Television
Replaced convergence board, fixed problem, and now want spare.
The usual order of probability I have found is:
Semiconductors
Electrolytic caps
Regular caps
resistors
inductors/trnasformers
Static testing OFTEN will not reveaal the failure.
Dec 31, 2009 | RCA D52W15 TV
Hitachi 51gwx20b service code
There is not a Service code to Enter into convergence on this set , on convergence board there is a switch on the very front of board WITH set on press and hold 3secs you should see convergence Pattern Appear after you release button. From the Front of TV remove Bottom cover then you will be able to see whole chassis,and the Little Blue contact switch.on same board you replaced ICs.
Jan 10, 2009 | Hitachi 51GWX20B 51" Rear Projection...
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
Blue convergence
SINCE YOU HAVE REPLACED THE CIRCUIT BOARD,THE NEXT STEP WOULD BE CHECKING VOLTAGES GOING TO THE CONV. BOARD COMING FROM THE POWER SUPPLY CIR. BOARD.....IF NO VOLTAGE METER,,SOMETIMES, THERE ARE FUSES ON THE POWER SUPPLY CIRCUIT BOARD THAT SUPPLY THE NEEDED VOLTAGES FOR THE NEW BOARD YOU JUST REPALCED...UNPLUG THE SET,,CHECK FOR A BLOWN FUSE----I THINK THERE IS 2 OF THEM--ONE FOR A NEGATIVE VOLTAGE AND ONE FOR A POSTIVE VOLTAGE FOR THE CONVERGENCE BOARD..GOOD LUCK--SORRY, MIGHT NEED A TECH...TUNICA
Oct 30, 2008 | Samsung HCN653W 65" Rear Projection...
I recently purchased an RCA rear-projection TV from a friend, and I'm having some trouble with the convergence. It's model # P60925BL, serial #904251165. When I try to use it, the red and blue convergence...
since two colors are affected I would suggest checking the solder on the convergence power supply. If the solder is good you will most likely need a new power supply. The power supply board is the one without all the heatsinks next to the convergence board
Jun 24, 2008 | RCA Televison & Video
Hitachi 43FDX11B television Ghosting
I had the same problem on my Hitachi rear projection TV 53FDX20B made in Mexico. The blue convergence problem. Blue focus had shifted and appeared like a blue ghost image. I followed the step by step intructions from the fixya site. First Replaced the two STK 392-110 ICs and turned on the tv. No change. Then I went looking for the bad resistor. There was one resistor RK50 (2.7 ohm, 1Watt capacity) which is attached not right close to the printed circuit board surface but was well raised up from the board. The bands on the resistor were a little discolored. I replaced that one and turned on the tv. The convergence problem was solved. Thanks for the step by step instrucitons on your site.
Dec 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
