Question about Haier Commercial Cool 8,000 BTU Portable Air Conditioner CPRB08XCJ
I need an exhaust hose for cprb08xcj
I purchased an exhaust drier hose but it does not work. all we get is hot air. We lost the original hose when we moved from Pa to NY......Help It is a commercial cool portable air condictioner
  • 24 Answers
SOURCE: exhaust hose
i could not find that model number on the haier website www.haieramerica.com you can get the manuals and parts list there. you dont need the haier hose however lowes and home depot sell what im guessing is three or four inch hose that you can use say a dryer vent flex hose or alumaflex hose to connect this unit. unless you are going for the looks.
Posted on May 31, 2009
  • 29 Answers
SOURCE: I purchased a Commercial Cool Haier portable
Check the compressor. It probably fell out of it's mounting bracket during shipping. Maybe turned upside down or something. Make sure the compressor is sitting solid and it's rubber feet are in place. If you continue to use this unit with a loose compressor, you may damage or break a refrigerant line.
Posted on Jul 08, 2010
  • 4736 Answers
SOURCE: I have a Haier Commercial
Mark, the two hoses serve different functions (Fresh Air Intake & Hot Air Exhaust). Therefore, they would have to remain separate. Also, Haier does not recommend extending the length of the hoses, to accommodate a specific change in installation. And yes, they can be vented through a wall to the outside. But, you would need to use something similar to a clothes dryer vent termination on the outside. Most exterior dryer vent terminations have insect screening and a flap door that opens when air from the dryer pushes it open. This would be fine for the exhaust hose, but not the Air Intake Hose. I guess if you could carefully remove the flap door. it could be used on the Air Intake hose. Also, keep in mind that the unit requires a minimum of one foot air space clearance off the back of the unit, for proper air circulation around the unit. If clothes will be hanging in this closet, that may present an air circulation issue.
Hope this helped you, please let me know. Thanks.
Posted on May 26, 2011
  • 4736 Answers
SOURCE: Hi I've just purchased a used
Harry. if you purchased it from a brick and mortar store, rather than online. Return it to the store for replacement. Or you can get it from Haier under warranty, with your Proof of Purchase. It's more to it than just the air intake and the exhaust hoses.
You can contact Haier Customer Support at 877-337-3639.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 02, 2011
Testimonial: "thanks for your help - very useful"
  • 4736 Answers
SOURCE: I have a commercial cool
Karen, the flashing red light indicates that the water collection tank is full and needs to be emptied.
You can finds the drain plug on the rear of the unit just above floor level.
It can either be drained into a low sided bowl or pan capable of holding 1 quart of water. or you can disconnect the exhaust hose(s) and roll the unit to a floor drain or outside to drain it.
Hope this helped you and thanks for choosing FixYa.
Posted on Sep 06, 2011
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
Where do I check the freon gas level in my Haier CPRB08XCJ
There are generally no fitting to connect to the sealed systems of portable air conditioners. You can buy a 'saddle valve' that will pierce the suction side and allow you to check low side pressure, but they will allow a very slow leak in most cases.
It likely uses R134a instead of Freon.
Jul 23, 2014 | Haier Commercial Cool 8,000 BTU Portable...
Installation diagram
240 volt electric cord, and a flexible usually 4 inch, exhaust hose.
Install cord to drier.
Install flexible hose to driver using the clamps provided.
Install plug into the 50amp drier outlet.
Install the other end of the exhaust hose to the vent going outside.
Carefully move the drier back into position almost against the wall without crushing the vent hose..
May 07, 2014 | Dryers
I do not have the exhaust hose for my AC. Should I not run the AC since it is blowing hot air into the room as well as cool?
No you should not because it is counterproductive. You can always purchase a new exhaust hose at your local hardware store!!!
Aug 10, 2011 | DeLonghi Pinguino PAC-210 Air Conditioner
How can i find the attachable hose for this unit?
I don't know exactly ...
But, I'm gonna try to help you.
Are you talking about the water disposal or are you talking about hot air disposal, you are not clear on that.
In either event, if you cannot get what you require from the manufacturer or the store where you bought the product or, a store that sells the product or similar products, you may have to adapt hoses readily available at your local hardware store.
Think garden hose for disposal of water and think drier exhaust pipe (hose) for hot air. Your hardware store shouldhave a big variety of hoses from which to choose.
I hope this response pleases you. Thanks for using FixYa.com
Jun 27, 2011 | Toyotomi TID-1200 Air Conditioner
I have a challenge 414/0038 air conditioner / dehumidifier. The hoses are missing. Can I use the dehumidifier without hoses? Where can I get a spare hose from if I need one? Thank you
No, you musn't use this air-conditioning unit without the hose. The hose vents the hot air outside, so if you don't have a vent the hot air will be inside and make the room warmer instead of colder.
You should be able to use any vent hose, like you would buy for a tumble drier etc from any spares shop
Apr 28, 2011 | Dehumidifiers
My drier gets warm but not hot???whats wrong....I check exhaust system cleaned it and vent system too. power is normal I put it on express drying too and warm not hot?
Most electric driers have two heater coils, inside that provide heat to dry the cloths. Wires like in a light bulb only bigger. I suspect one of these coils is burnt out and thats why it is only getting warm not hot. Also be sure to remove the hose from the back of the drier and check for a restriction there.
Oct 08, 2010 | Kenmore 63942 Dryer
Drum turns and you feel some heat but does not dry clothes
check to make sure you have no lint buildup in the drier itself along with lint build up in the exhaust hose leading from the back of the drier. If there isn't proper exhaust from the lint filter to the outside of the house or apt. then the clothes will get hot but still be wet.
Hope this helped
Dave
Mar 02, 2010 | Frigidaire GLER331A Electric Dryer
My dryer runs and gets hot but takes 2 or 3 cycles to dry .
Please check your exhaust line fron the lint filter to the outside vent. When I say check, what I mean is take the machine away from the wall remove the hose and vaccum out the drier outlet --- use the crevice tool. When you are done with this, put a nylon over the end of the outlet and turn the drier on. You should have a good amount of air coming out. There will probably be lint - the reason for the nylon is to catch it. If not - do it again. (use the air setting) ... do the same with the hose. If you have access to the other end, disconnect it as well .. check that the door on your outside vent is not stuck shut. If you have a plastic hose, please replace it with a flexible metal hose.
I hope this helps you
a
Oct 02, 2009 | GE DBXR463EBWW Electric Dryer
Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
May 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Haier Commercial Cool 8,000 BTU Portable Air Conditioner CPRB08XCJ Logo
94 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
