Question about Element Electronics FLX3210 32 in. LCD TV
Code for my WOW remote to operater Element TV
I followed steps on the WOW remote but it would not operate the new Elelment TV.
3 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: no codes for a mediacom remote control for my element tv? help! please....
A lesson to learn--not all remotes will program for all models--a limited number of codes are in most remotes and that set likely has a odd one--way to try to force people to buy a remote from them.
Posted on Jun 17, 2012
Testimonial: "My Devry (only) edumacation told me that I was not going to find a code, I just wasn't sure if anyone figure out how to work around what is pre-programmed (in other words programming a remote). Oh well, no biggie, I'll just rubber-band my two remotes together..... there's a solution (and not at ALL an eye-sore) THANKS THOUGH, MR. SD TECH!"
gopakumarg43
  • 75404 Answers
SOURCE: i have an element 55' tv...model# elgfw551...i just bought a rca universal remote...and now i cant find the code to program the remote for the tv...help please
000,065,029,061,069 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Posted on Apr 02, 2013
Is there a code for Elelment TV Model FLX1510
If the code is not listed and the remote is not programmable, you won't have much luck.
Sep 22, 2014 | Televison & Video
Www urcsupport com
Use the auto code search function of the remote.
Apr 20, 2017 | Televison & Video
I've searched far and wide, starting with RCA too no avail. Just don't see a model number or any program instructions. Again, it's a very old remote.
Wow ,, without the model number for that it will be very hard to give you step by step instructions or even tell if its compatible. but dont fear there is a possible solution. Notice that code search button the the remote ?? well basically some TV's share the same code so even if it inst listed doesn't mean it wont work.. Unfortunately you will need manual to tell you the exact procedure, but it should be something along the following..
1.) turn the tv on
2.) press and hold code search for 2 seconds or more until the LED lights continuously,
3.) press the tv button the led should blink and go out or bink and come back on.
4.) press the power button, if the tv turns off press the enter button to store the code.
5.) if nothing happens repeat steps 4 and 5.
Dec 27, 2012 | Televison & Video
Need code to make universal remote work on sony tv
hello sir,
i m having problem please n please solve it........
i hv recently buyed a new LCD Sony Bravia KLV32BX300 ON 2nd FEB. 2011 and im having Airtel digital tv HD alos and i have connected LCD and DTH with HDMI cable ok....then problem is that how to make my DTH universal remort to operate my tv remort sensor..how to sync..my sony remor with dth remort..and i have try my best but im faild i know my dth remort code that is [OK+2] HOLD THESE buttons atleast 3 sec. ...............tell me what was my sony bravia pairing code.........please please nnnn please
Oct 25, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
I HAVE A NEW BLC320EM98 TV AND NEED TO PROGRAM TV REMOTE TO WORK ON "COMCAST CABLE". None of factory codes woek. What does?
In your packet there should be a set up sheet for the remote when you try to set it up follow the search guide for the remote to search and find the comcast box. Depending on how the search works on that remote it may take some time and you may find more than one setting that will work. Then you have to choose the best one that operates the comcast box the best. Good luck and be patient.
Oct 14, 2009 | Televison & Video
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Will not turn off or on or change volume with remote
If you have verified the functions work by using the buttons on the TV then do the following.
If the remote does not work now then you may need a new one.
Mar 10, 2009 | LG 42LC2D 42 in. LCD HDTV
Remote control setup
please follow the steps below:
TV
RED + SELECT
TV
0056
try your volume button if this works press the SELECT button to save the code. if not press TV and then try the volume again. repeat this step until the volume works. then remember to press the select button to save the code
cheers
Little Dish Fitter
Jan 07, 2009 | LG 42LC2D 42 in. LCD HDTV
Element Electronics FLX3210 32 in. LCD TV Logo
297 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
