Question about Philips 32PT6441/37 32" TV
I have a philips 32PT6441/37 32" and everytime I switch the tv on, the light next to the switch button flashes red but the tv does not come on!! Pls advise if this can be fixed. Thanks.
  • 1,694 Answers
Install horiz driver kit # 483531057673 and replace 47mf/25v
capacitor in horiz drive circuit. Fix applies to all L04.01U chassis.....................................T.
Posted on Nov 25, 2007
Check vertical output supplay or def vertical ic] check horizontal driver transistor check fly back
Posted on Sep 04, 2007
I don't know about this particular philips chassis but I've got a phillips tp3281 with a #32d700-7570 chassis with the same problem: apparently common with philips sets. I opened mine up and discovered the burnt capacitor that others have reported, replaced this as recommended with a higher rated one. In many cases this is apparently ALL that is required to fix the prblm (a 50 cent part)unless other components are also damaged which appears to be the case with mine. This repair is about $150 here locally at a shop which I didn't want to put into a relatively old set. Have you opened up your set yet? Do a Google search on your set and you might find that others have had the same problem and a simple fix could be possible. Also you could check the following site as they seem to be quite savvy and responsive with TV repair questions:; Hope that helps!
Posted on Aug 30, 2007
Tv wont turn on
I have no clue who makes your TV or the model so I can't really help you. Count how many times it flashes and start googling for the answer. Include all the info you can next time.
Dec 29, 2012 | Televison & Video
Need the code for a sanyo tv to use a philips universal remote
Universal remote code to be cheked with Philips CL034 model remote habset to Sanyo are;
0506 0311 0612 0002
0428 0802 0412 0619
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
NB: Switch OFF and switch ON your TV with its front panel power control switch each time before trying an other code.
Feb 16, 2011 | Philips Televison & Video
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
Oct 11, 2017 | Televison & Video
Philips FTR 9964 tries to switch on but light above power switch flashes red
Jun 05, 2009 | Philips FTR-9964 Tuner/Receiver for Plasma
The tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Apr 21, 2009 | Toshiba CF36G40 36" TV
Philips 14inch color power problem
Take it back where you bought it.If its still under warranty, they'll work on it.If its not,they'll still advise.Hope that helps!
Jan 11, 2018 | Philips 14PT1686 14" TV
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Philips 32PT6441/37 32" TV Logo
223 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
