DATA TECH 2170 SHREDDER PARTS MANUAL - Office Equipment & Supplies
Mx808 sentinel shredder
Is there a manual for this shredder? Where would I locate that? I want to oil it but don't know how or where! HELP! New to me shredder and no manual - it is noisy.
Apr 27, 2013 | Cross Sentinel 10 Sheet Cut Shredder
I wish to connect a Teac DV-2170 DVD Player to an LG Television. LCD TV Model 42LE5310. I do not have the DVD Manual, do have a 3 cable, red, yellow, white connector. What else do I need and how do I...
Dear allanjj ,
please click this link to get you Teac DV-2170 DVD manual.
http://ernie.awa.com.au/ArticleDocuments/2246/TEAC%20DV-2170%20Instruction%20Manual.pdf.aspx
please read this manual to clear all your doubts
Thanks
Jun 19, 2011 | Teac Esoteric DV-50 S DVI Model In Stock
Where can I get new gears for my Tech Solutions TS8000 paper shredder
Unfortunately there are no replacement parts for many shredders...they are made to throw away when the break...
Stinks... but that's the way it is...
heatman101
Jun 15, 2011 | Tech Solution TS-8000 Cross-Cut Shredder
Have a tech solutions 4500. how do you lubricate it?
  1. Cross cut shredders require more frequent oiling versus the straight strip shredders. The more paper and use it gets the more oil it requires. A good rule of thumb is to oil the machine each time you change the bag.
  2. Use only shredder oil designed for the specific brand of paper shredder you have. Manufacturers design paper shredder oils to be heat tolerant for the cylinders and blades, and they calibrate them specifically for their machines.
  3. Spray, squirt or run a bead of oil across the blade opening. It shouldn't take more than a second or two to reach from one end to the other. Any more than that may result in too much oil applied. Quicker than that means there isn't enough oil to adequately lubricate the machine.
  4. Turn the paper shredder to "Manual" and run the gears in reverse for a few seconds, then turn the shredder on "Forward" or "Standard" mode. This ensures that you distribute the oil throughout the machine, and going in reverse first forces some of the dripping oil back up, and then the forward moving blades push it back through the gears.
  5. Oil a sheet of paper rather than the machine. Don't just run a bead of oil across the bottom of the sheet because the paper soaks up the oil and the oil may not reach all of the necessary parts. Instead, spray the whole sheet, or run a zigzag line across the paper and immediately send it through the shredder to oil it.
Jan 28, 2011 | Tech Solution TS-4500 Shredder
I need a parts and owners manuel for a Super Tomahak Wood chipper made by Garden Way Mfg. Co. where do I go to get one?
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.brentchalmers.com/
I note your looking for the Super Tomahawk. If you can come up with a model number I think I can find your parts manual for sure. (or at least an on-line parts list.) Also.... If you can come up with an engine number like OH120 or L90 off of the engine I can find you a manual for the engine also.
This is the list of Manuals available there:
  • 1983 W-W Grinder Inc. Manual and Parts List Super Tomahawk 5-8-2G/C and Tomahawk 5-8-2G/M Chipper/Shredder (40 Pages)
  • 1989 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1989 Troy-Bilt Technical Manual 4HP, 5HP, & 8HP Models Tomahawk Chipper/Shredder (12 Pages)
  • 1991 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1991 Troy-Bilt Knife Kit number 1772231 (1 Page)
  • 1992 Troy-Bilt 5HP Model Service Kit (Part Nos. 1901153 and 1901804) For Chipper/Vac (1 Page)
  • 1992 Troy-Bilt Owner/Operator Manual 47260, 47261, 47271, 47272 Chipper/Vac (60 Pages)
  • 1993 Troy-Bilt Sales Brochure Chipper/Vac (4 Pages)
  • 1993 Troy-Bilt Owner/Operator Manual 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (44 Pages)
  • 1993 Troy-Bilt Parts Catalog 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (16 Pages)
  • 1994 Troy-Bilt PTO Chipper/Shredder Owners Dog Clutch Kit 1902404 (1 Page)
  • Hopefully your model is one of the above.
    Here is link to the Parts manuals:
    http://www.partsandservice.com/html/TroyBilt/cs/
    There are 90 parts manuals there.
    Again with a good model and engine number I can probably come up with your exact manuals.
    Thanks for chosing FixYa,
    Kelly
    Oct 20, 2010 | Troy-Bilt Chipper Shredder
    Where do i get a plastic gear to turn the shredder
    Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
    http://www.compax.com/shredders/parts.html
    http://wheelermachines.com/manufacturer.html
    http://www.manualsonline.com/ex/thread/view/idThread/1735067
    Jun 24, 2009 | Tech Solution TS-4500 Shredder
    Looking for a replacement gear for our shredder
    This is how a got my hard to fine gear!
    Contact Michael Business Machines for your local dealer 1-800-223-2508
    Good luck, Tom
    Jan 03, 2009 | Tech Solution TS-6000 Shredder
    TS-6000 Shredder Problem
    1800 639 3803 tech solutions service hot line for the ts6000
    Aug 18, 2008 | Tech Solution TS-6000 Shredder
    Manual guide shredder ams 3000
    Heres a few sites that have gears and parts
    Apr 17, 2008 | Ameri Shred AMS-3000 Shredder
    My shredder keeps running and won't stop in on/auto mode
    Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
    Apr 07, 2007 | Tech Solution TS-4500 Shredder
    121 people viewed this question
    jasbo
    jasbo
