Question about Haier ESD300 / ESD301 Built-in Dishwasher
Pump motor humming cycle drain
Machine constantly draining but not loading water.
3 Suggested Answers
  • 2976 Answers
SOURCE: Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Posted on Feb 02, 2009
SOURCE: drain pump not working.
i use rapid program 30 M it is work suddenly 12 MINUTES ITS STOPwater cannot go out side after they make sound10s E4
Posted on Oct 02, 2012
How can I spin and drain my normal size load. I have an LG front loading washer m/n WM2455H and it will not spin and drain. I hear the hum of the pump, so it isn't that. Went through all troub
It is most likely the drain motor even though you hear it humming. The LG drain motor impellers usually wear out on the motor shaft, and the impellers then just end up wobbling. The result; a drain motor that no longer drains water.
Sep 13, 2014 | LG WM2455HG XL Front Load Stackable...
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Kenmore Front Load Washer
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
My machine is barely draining water on the drain and spin cycle. It will spin but does not empty all the water out of the machine.
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 21, 2012 | Frigidaire ATF6000ES Front Load Washer
The wash cycle clicks on and a small amount of water enters the drum, as normal, but then there is just a humming noise and the drum does not move. When I put it on the rinse and spin cycle (there is...
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
Jan 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine wont drain
check for faulty water pump or a blockage to the water pump see if you can here a hum when it is time for the machine to drain
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 18, 2010 | Tecnik TKL9260 Front Load Washer
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Kenmore elite catalyst wont drain or spin
Did you ever find out what is wrong? This is exactly what has been going on with ours.
Mar 25, 2009 | Kenmore Washing Machines
Machine not draining
the washing machine uses an electric pump. Unlike the older machines pumps that used to be driven by a belt, Then newer washers pumps are driven with an electric motor.The first thing you need to do is to disconnect the washer from the wall outlet
Next you need to remove the front panel from the washer. To do that you will need to be use a spatula. You need to place the spatula between the front and top panels to compress the two front panel holding clips.
After removing the front panel you need to connect the washer to the wall outlet.
Set the timer on the spin cycle and pull the knob to turn the washer on. Listen to see if you could hear the motor on the pump turning or humming. since the motor hums, that is an indication that something is preventing the pump motor from starting.
Disconnect the washer from the wall outlet, empty the water from the machine (make sure you have plenty of towels to clean any water spills) this connect the hoses from the pump and check the pump for any obstructions.
If the motor on the pump is not running at all, then you'll have to check the pump motor for continuity. If the pump motor checks OK for continuity then you need to check the two wires that connect to the pump to make sure that the timer is sending 120 volts to the pump.
In conclusion, is not that hard to find out why your front load washer is not draining. You either have an obstruction, a bad pump or a bad timer.
To check the motor in the electric pump you will need to get the multitester. analog multitester. Make sure you read the instructions on how to use you multitester to read resistance and voltage
Mar 14, 2009 | Tricity Bendix AW1000W Front Load Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Haier ESD300 / ESD301 Built-in Dishwasher Logo
Top Haier Dishwashers Experts
Renee Knafel-Bullock
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
