I have a Sony home stereo and it has an error on the screen that reads mecha error it won't play CDs
    Genius:
  • Audio Player... Master
  • 1,054 Answers
The loading mechanism is out of alignment. What model is it?
Posted on Jul 18, 2013
Dinoza
  • 112 Answers
SOURCE: No Disc error, won't read any CD
Another option is to try a lense cleaner CD, or doing it manually.
Posted on Feb 13, 2007
  • 3 Answers
SOURCE: shelf cds is blocked SONY CMT-HP7
To get the cds to play, and 5 to eject, you can try taking off the sides of the consul and using compressed air. As for the shelf problem, I'm not really sure.
Posted on Jan 19, 2008
likha
  • 790 Answers
SOURCE: E-Mecha...what does it mean?
Hi
What brand and model! and can you specify the trouble you encountered!
Posted on Jun 22, 2008
dahaka
  • 347 Answers
Hello cclub2002,
First try to turn it off and then on.
If that doasent work, turn it off for 10 mins and then turn it back on.
If the error continues, let me know.
By the way, to try to get your CD out, search for a hole (2 mms in diameter) It should be near the CD tray, but could be anywhere.
Once you locate the small hole, find a paper clip or smomething as pointy as it, and insert the paper clip in.
Press it had and the CD tray will come out.
Good luck and anything else you need let us know,
Dahaka
Posted on Jul 26, 2008
SOURCE: no disc
clean the laser lens maybe got some dust good luck
Posted on Feb 11, 2009
In my sony home theatre MHC - GZR88D i want to play music as dvd , usb ,etc.... ,don't played only one word is shown that mecha error , what can i do
Probably means there is something wrong with the DVD drive. Check that a disc is not inserted wrong. You could also try cleaning the DVD lens.
Jun 28, 2015 | Sony Audio Players & Recorders
JVC CA-D661T compact home stereo stopped playing burned CDs (it used to play these same CDs, now it doesn't recognize them). Everything else works, including playing of original CDs. Any ideas?
You can try cleaning the laser lens. You can do this using qtips and rubbing alcohol. Be sure you are very gentle though or you could risk scratching the lens which would completely ruin the laser assembly.
Mar 21, 2012 | Car Audio & Video
How to fix mecha error on sony mhc-gx555
https://us.en.kb.sony.com/app/answers/detail/a_id/38877/~/the-stereo-system-malfunctions,-stops-responding,-or-displays-mecha-or
Jan 09, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
My MHC-GX450 worked fine for several years. I just went on vacation for two weeks and before I left, I unplugged it so lightning would not cause power surge damage. When I came home and powered up, it...
After calling SONY support, they wanted me to send the entire system - speakers, cables... Please! That's is dumb, and the rep had to be reading it from a script.
So I managed to get the covers off and figured it out on my own. The drive belt for the CD tray had come off the pulleys. I simply put it back on and... Voila! Saved myself hundreds of dollars for a $2 belt. I called SONY and ordered two spares. Sometimes, if you have some mechanical and basic electrical skills you can save yourself a lot of money and aggravation.
Sep 22, 2011 | Sony MHC-GX450 CD Shelf System
Cannot open cd tray. Cannot rotate cd's. Plays only one cd and intermittently. Get 'mecha error' message. Had similar problem last year without 'mecha error' message, which was...
In some cases this is due to the main spindle getting jammed or there are mechanical errors which as mentioned needs a reset.
Also in some cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jun 25, 2011 | Sony MHC-RG290 Shelf System
DespLady
It is error message of HiFi when it finds problem in Tape Mechanism. Tape mechanism is stucked and needs to be reset. Open your HiFi and rotate the capstan wheel with finger and then try to power up.
Jul 20, 2008 | Sony MHC-GX450 CD Shelf System
Shelf cds is blocked SONY CMT-HP7
Nov 09, 2007 | Sony CMT-HP7 CD Shelf System
Mecha error
I had the same problem. My unit would not eject CDs. I was able to fix it by hitting the reset button. That restarted the whole unit and reset all the settings as well, but now I'm not having any issues with ejecting CDs.
Oct 22, 2007 | Kenwood Excelon DDX-7015 Car DVD Player
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
303 people viewed this question
 Grubhead
Grubhead
