Question about Robert Yick Co. RanRYC168 Gas Kitchen Range
GE Spectra Water stains on glass heating unit does not respond to recommended cleaning solutions. Have tried removing the stains with water, dobie pad, vinegar, and bon ami. Will next try cerama bryte. could finish have been damaged? any way to remove stains? can glass top be replaced?
  • 63 Answers
Try bars keeper
Posted on Aug 29, 2007
What can I use to remove a stain of SOYSAUCE in a carpet?
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Nov 21, 2014 | Heating & Cooling
How do I get the white heat stain off of my tempered glass, air tight gas furnace?
You'll need to remove the glass from the fireplace, but not before turning off the pilot light. Then mix a 50/50 solution of White Vinegar & Water. Using a sponge soaked in the solution and partially wrung out, clean the glass on both sides using the solution & sponge. Reapply as necessary until the glass is clean. Dry thoroughly with paper towels, before reinstalling the glass.
The heat stain is not really a heat stain. It's left over residue, from when someone used commercial glass cleaner to clean the glass. The white stain is from the ammonia in the cleaner.
Hope this helps you and thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
Self-cleaning feature
Check your owner's manual, but most self-cleaning ovens should not be cleaned with chemicals. The finish can be permanently damaged. You might try running the oven through the self-cleaning cycle more than once. It will take some time. Make sure the room is ventilated properly since the cleaning cycle produces a lot of heat.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hard water stains on my car's wind screen
Windex and newspaper should do. You sure they are water spots and not the glass? When they set out the plastic impregnated in the glass (safety glass), seperates slightly and looks like a water spot or even a bubble. It is a combination of heat & sun rays. May have to live with it or replace the glass.
May 03, 2009 | 1995 Mercedes-Benz E-Class
How to clean stainless steel
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard may try a localized..(just for the DW and kitchen sink area) filtration reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Water Stains on GE Spectra Ceramic Glass Top
Aug 28, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
Regular spill stain problems
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at
Jun 13, 2007 | Maytag MEC5430 Electric Cooktop
Oven window
Dec 07, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Robert Yick Co. RanRYC168 Gas Kitchen Range Logo
138 people viewed this question
Top Robert Yick Co. Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Robert Yick Co. Kitchen Range Expert? Answer questions, earn points and help others
