Question about Home
Aspen whitewater shower
Where can I buy plastic cover for the mixer tap for an Aspen White Water shower unit ?
  • 13433 Answers
SOURCE: Aspen watch
this should work with your aspen watch let me know if it doesn't
http://dive.scubadiving.com/members/gearreviews.php?s=593
Quote
For the alarm: If you want to use it (I think both it and the light use battery faster than when not used), you set it by pushing mode button twice, as indicated above, then go to hour or minute setting by pushing the lap/reset button, and advance to the time you want by pressing the start/stop button. Pushing mode will take you back to normal time again.
To turn alarm on or off, hold lap/reset button in and at the same time push the start/stop button. Alarm icon will show on or off. When you release the lap/reset button, it will revert to normal time.
If the alarm is on, at the designated time it will start beeping for awhile or until the lap/reset button is pushed (off) or start/stop button (snooze).
Posted on Aug 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: shower mixer taps
look for a scald safety screw adjustment. Remove the handle, and it is underneath. this is for safety of young children, and is factory set.
Posted on Dec 23, 2008
  • 3 Answers
SOURCE: Conversion instructions for the Graco Aspen 3-in-1 crib
I have the instructions still but the crib was recalled
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09260list.html
Posted on Jul 19, 2009
  • 23 Answers
SOURCE: i have a shower unit running from my bath taps the
there is an ajustment on most tub and shower valves, remove handle and there is a plastic peice that stops the handle from turning to the hot side to much. try to adjust. you shouldnt have to shut water off to house, but to be safe you might want to.
Posted on Oct 31, 2009
SOURCE: Aspen watch
Setting my Aspen Digital Watch
Button designations:
(NITEGLOW) B C (START/STOP)
10:47
(MODE) A D (SPLIT/RESET)
To Set Time, Date and Day:
Press A 3 times; Seconds Flash; Set to 00 with C
Press D; Minute Flashes; Set Minutes with C
Press D; Hour Flashes; Set Hours with C
Press D; Date Flashes; Set Date with C
Press D; Month Flashes; Set Month with C
Press D; Day Flashes; Set Day with C
Press A to Quit
To Set Alarm Time:
Press A 2 times; Hour Flashes; Set Hour with C
Press D; Minutes Flash; Set Minute with C
Press A to Quit
To Set Alarm ON or OFF:
Hold D in to see Alarm Time and Press C to toggle Alarm ON/OFF
Operation:
Hold C to see Month and Day.
Hold D to see Alarm Time; Press C to toggle Alarm ON/OFF.
Posted on Dec 21, 2009
I have a bath shower mixer with a shower set. I cannot get water to come out of the bath tap, only for the shower head. The fitting in the middle if the taps will not stay down.
Go right away back for replace if there is warranty in between 8 days, if not then there should often a simple mixer maintenance set for sale for the brand and exact model mix faucet. often from simple plastic if its an older (mostly solid) mixfaucet then only to put it 24 hours in a bucket of vinegar or descaling agent.
Mar 01, 2017 | Home
Zip code for 2311 Aspen Road, Ames, Iowa
2311 Aspen Rd Ames, IA, 50010 - Condos for Rent ' Zillow
www.zillow.com > Iowa > Ames > 50010
ZillowView 10 units for 2311 Aspen Rd Ames, IA, 50010 - Condos for Rent, as well as ... Ames Middle (assigned). 6-8 ... Nearby ZIP codes include 50012 and 50013.
2311 Aspen Rd Unit 101, Ames IA, 50010 ' Homes.com
Dec 16, 2015 | Computers & Internet
Where is the fuse located for my headlights in a 2008 Aspen?
THE FUSE BLOCK IS LOCATED IN THE LEFTSIDE KICK PANEL BEHIND A REMOVABLE COVER NEAR THE PARK PEDAL. A FUSE PULLER IS ATTACHED TO THE INSIDE SURFACE OF THE FUSE PANEL COVER TO AID IN REMOVING FUSES.
Dec 18, 2014 | 2008 Chrysler Aspen
Power window 2007 aspen
Try pulling back the wire harness cover between the left rear door and the door frame, usually a wire within is cracked or totally broken. It happened on my 2007 aspen. First it was intermittent than no power at all but this did the trick. good luck. tjm
Mar 30, 2013 | 2007 Chrysler Aspen 4x2
Where is the pvc valve on an aspen with a 5.7 hemi?
ITS PCV VALVE YOU WILL FIND IT ON TOP OF THE VALVE COVER IT HAS A HOSE HOOKED TO IT IT GOES TO YOUR INTAKE MANAFOLD TO KEEP BLOCK PRESSURE FROM BUILDING UP HOPE THIS HELPS YOU GOOD LUCK BOB
Apr 25, 2011 | 2007 Chrysler Aspen 4x2
Replacing rear brake light on 2007 Aspen. Removed plastic pins but lense cover will not come off? any ideas?
There may be one that is "hiding" from you. I think that there are normally 3 that you have to take the nuts off of thru the back hatch. You may have to tug a little harder>
Mar 12, 2010 | 2007 Chrysler Aspen 4x2
The shower no longer cuts off completely leaving a constant drip from the shower head. I disassembled the valve body and discovered an unusual plastic split plate gate valve system inside. It appears to...
If the Shower or any tap keeps dripping then its from were the cut off of water comes from and if 2 taps then its either the seal and the seat needs recutting so the answer is to get the plumber out to recut the seat
If a mixer tap then you will have to get a replacement unit.....sorry
Sep 24, 2009 | Home
Positve and negative speaker wires for 2008 chrysler aspen
Hello latinoheatj5,
According to modified life.com the speaker wire colors for the 2008 Aspen are:
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Orange
You can go to their web site here for other radio wiring color codes.
http://www.modifiedlife.com/2008-chrysler-aspen-car-stereo-wiring-diagram/
Mar 31, 2009 | Alpine Car Audio & Video
Home Logo
119 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
