Question about Drive Medical Drive Phoenix 4 wheel scooter *Free Batteries/Free Home Delivery!
Flash codes what does it mean when the green light flashes in a sequence of six flashes
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
How can fix my error 5b00
Your video doesn't quite show how many flashes in the sequence.
six orange flashes means the CD tray door is down, seven orange flashes (the 5B00 error) can be addressed as below. Good Luck.
5B00/5B01 - Orange and green light blinking 7 times Description: A service error has occurred. Resolution: 1. Turn off the printer. 2. Disconnect the power cable. 3. Open the printer cover. 4. Check for any orange protective tape or white polystyrene and remove if necessary. 5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary. 6. Close the cover. 7. Reconnect and turn on.
Jan 06, 2015 | Canon PIXMA Office Equipment & Supplies
Green light,then red flash.No obvious sighn of capacitor damage,tried heating no go
Count the number of flashes for both the red and green lights and make note of any sequence. Now, Google your make and model with the words blink codes added to the end. From there you will be directed to numerous sites that will tell you what the blink code means.
Sep 04, 2011 | Televison & Video
Cannon Pixma ip90 printer mechanical failure code 5100. Printer works for about 2 inches then stops with failure code 5100
The error 5100 actually means nothing. You need to look at the printers green and orange lights. they will be flashing in a certain sequence. Count the way the lamps flash ie.Green are mechanical faults and orange are operator correctable faults. When you have the info repost and i will help you further.
Jul 27, 2011 | Canon Office Equipment & Supplies
Just installed new printer Lexmark E260dn all lights flashing- printer does not print
This light sequence means that the printer has a service error, and printing has stopped.
Please Press Continue button (green button) twice to see the secondary code. The secondary error code will help locate the problem. Please take note which light will be flashing for this will reveal what problems you have on the printer.
For further assistance, please contact Lexmark Technical Support.
Feb 20, 2011 | Lexmark E260dn Laser Printer
I have a 50in tv and when turning on the green light flash and the the red comes on and flashs
count the number of flashes when you turn it on, usually that is a "code" or sequence that you can look up, for example green flashes 5 times and red flashes 9, you then can look up the code for "flashing 5,9 codes" hope this helps.
Mar 31, 2010 | Sony KDSR50XBR1 50" Projection HDTV
What does it mean when the word "HOLD" appears blinking on my dashbord, I believe it has to do with the gears
Yes the HOLD light comes on when the computer detects a malfunction with the transmission....one quick flash of the hold light means a 01 code. six quick flashes would mean a 06 code. 5 long flashes would indicate a 50...6 long flashes would indicate a 60 code. Hope this helps.
Mar 14, 2010 | 1994 Mazda 929
Red light and 2 green lights on front panel on.
This is an error code it means the TV is in protection mode. Which means it has detected a problem and is preventing power up so not to cause further damage. Error codes are generally 2 numbers 1 seq of flashes a pause and a second sequence of flashes. Most common problems for LCD are Video logic / Main input board or the power supply. For more info and possible solutions post your make and model.
For parts and info check.
http://www.RNS-Systems.com
or E-bay
Oct 20, 2009 | Televison & Video
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Flashing red light
If the sequence is 4 red, green, 4 red, green and so on- that's a code that indicates your battery is failing and is only providing less than 25% of its normal charge capacity.
That would mean your battery is basically dying and will probably keep headed downhill in a hurry. You should probably go ahead and start looking at getting a replacement.
Dec 27, 2007 | Dell Inspiron E1505 Notebook
Drive Medical Drive Phoenix 4 wheel scooter *Free Batteries/Free Home Delivery! Logo
20 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
