Question about Kitchen Ranges
Acopos troubleshooting i have this alarm in acopos 1045 time out for enable cyclic network
2 Suggested Answers
SOURCE: fault no 41001 in acopos
install a new cooling fan to the bottom of your unit ,this will keep your heat sink cool
Posted on Feb 25, 2013
Hello my cannon ip 4950 flash 10 times...what can i do... thanks
if that cyclic blinking of alarm leds for 10 times and shown .B200 .maybe:
Internal temperatur of:
Print head
Logic board
Power supply unit
Nov 08, 2016 | Cannon Office Equipment & Supplies
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Computers & Internet
Acopos 1090
Sir What section bower board and control cart what section check the" resistor" sir
Feb 14, 2014 | Kitchen Ranges
Acopos 1090 booting problem
The issue is that the line filter and the integrated resistor can not secure the restart, so you have to check with your "resistor"
Feb 14, 2014 | Computers & Internet
How to connect wifi in lenovo g575
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
Troubleshoot network connection problems http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-network-connection-problems Lenovo support http://www-307.ibm.com/pc/support/site.wss/migr-50402.html
Apr 02, 2013 | Lenovo G575-438343u Amd E-350 1.60ghz...
What is error code 6500?
This is an error indicating a problem with the Logic Board Assembly. It's probably not worth fixing, with printer prices being fairly low.\
According to the MP800 Service Manual:
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Green (COPY button), or
Alarm LED Lit in Orange)
Service call errors are indicated by the number of cycles the Alarm LED and COPY button blink, and the corresponding error
code is displayed on the LCD.
*Cycles of blinking in orange (Alarm LED) and green (COPY button) - 20 times
*Other hardware error - Error
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
Aug 21, 2010 | Canon MP830 All-In-One Printer
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
Motorola RAZRV3x - alarm only works sometimes
TRY TO DELETE THE ALL ALARM FIRST THE NEW ALARM AND CHECK THE TIME AND ALERT SET UP IS CORRECTLY?U MUST CLICK THE DISABLE WHEN THE ALARM START WORK,THEN CLICK OPTION TO ENABLE TO CONTINUE USE IF u WANT SAME TIME ALARM WORK.DON,T CLICK SNOOZE WNEN ALARM START FUNTION.IF U REALLY WANT SNOOZE,PLEASE REMEMBER TO DIASABLE THEN ENABLE TO SET ALARM TO CONTINUE FUNTION.REPLY ME rose89my@yahoo.co.uk,thk!
Jul 21, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Cyclic redundancy check error
Trying Downloading Quick Install for the WUSB300N from
www.linksys.com
Feb 29, 2008 | Linksys WUSB300N Wireless Adapter
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
