Question about Zebra PRINTER - RW420 - 4 Inch DIRECT THERMAL (DT) RUGGED MOBILE RECEIPT PRINTER - CPCL/EPL/ZPL -... Printhead, Transfer Belt, Cable
Zebra printer printing skips
I always get zebra printer with printing skips problem, the printer is set on label & black mark sensor (bar sensor) sometimes it is as bad as a print followed by an empty paper for every print. reset the printer send command to configure most of the time it doesnt solve my problem. replacing bar sensor works sometimes but some cases it doesnt. is there any command to send to the printer to reconfigure it to detect black mark on paper & paper length or any advice at all?
Bubbabear64
  • 2794 Answers
SOURCE: Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Posted on Jul 29, 2008
  • 6 Answers
SOURCE: Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Posted on Sep 25, 2008
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
  • 7 Answers
SOURCE: just tell me how to
To reset the printer.
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Posted on Jan 29, 2009
  • 185 Answers
SOURCE: Zebra TLP 2844 Desktop Printer
The printer driver should be set to Continuous or it will think it is still Gap or Black Mark. Please adjust accordingly
Posted on Dec 20, 2009
Advancing blank labels inbetween printing
Do you use adhesive labels? It looks like the printer is unable to make the difference betwen the labels. Verify that the printer it's not set on Continuous mode for the media type. Verify if there is any label (or pice of label) stiked on the upper media sensor (gap sensor). You can locate the upper media sensor using the User Manual (page 74). There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
You can clean the sensor with an coton cloth dampened into isopropylic alcohol.
Here is the link to user manual:
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
Dec 03, 2013 | Zebra 105Se Thermal Printer
Skipping labels
Nov 27, 2013 | Zebra 105Se Thermal Printer
Rw420 skip printing
Kindly post the output to the command "debug client <printer MAC address>".
Can you also post the output to the command "sh interface detailed zebra".Or in case You Still Having Brother Printer Problem Then Follow Us For On: Printer Support Team
May 14, 2013 | Zebra PRINTER - RW420 - 4 Inch DIRECT...
My Zebra printer is skipping three labels
if black bars on the back of tags, go to control panel, printer pref, advanced settings, tracking media should be mark sensing, then if using QBPOS, when printing select
use black bar indexing
Sep 11, 2011 | Zebra TLP 2824 Printer
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Nov 03, 2010 | Zebra QL 320 Thermal Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
My printer won't caliberate using a 1.25 inch circular label. The label stock is white, the backing is an opaque whiteish with black lines between each...HELPPPPP
Zebra printers use 2 methods to sense the gap between labels. Transmissive or Reflective. Your labels have a black mark on the backing. Your printer uses these black marks to detect the gap between your labels. Ensure that your printer's mode is set to REFLECTIVE & check that your printer driver media also is set to BLACK MARK. Print a config label to look at your printer settings.
Nov 06, 2009 | Zebra 110Xi III Plus Thermal Printer
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Skips Bar Code Labels
It could be software related.  The best way to find out is to restart the computer where the labels are coming from.  Turn your printer off and back on again as well.  Run the program that loads the forms into the printer to print with.
Is the printer on an ethernet connection or is it connected to a computer?
Oct 21, 2008 | Zebra Z4Mplus Label Printer
Zebra PRINTER - RW420 - 4 Inch DIRECT THERMAL (DT) RUGGED MOBILE RECEIPT PRINTER - CPCL/EPL/ZPL -... Printhead, Transfer Belt, Cable Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
