Panasonic th 42pw5
Speakers buzz but no sound coming out. Pic is fine and all connections have been checked. Thanks!
redhead7377
  • 51 Answers
SOURCE: buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Posted on Sep 09, 2008
SOURCE: Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Posted on Jan 05, 2009
SOURCE: Panasonic Viera TH-50PZ80U No sound no audio only buzz.
Found the screen had a small crack and was shorting the video circuit.
Posted on Jan 09, 2009
  • 814 Answers
SOURCE: Panasonic TC-32LX70 buzzing sound from speakers
You may have rerouted your cable too close to a live connection. The magnetic field from the power line is causing interference on the television cable. You will need to either reroute the cable or shield it from the interference. This can be done with a metal covering separating The wires from the cable. It can also be caused by a bad ground connection in the house. The bad ground will allow noise to appear on the ground of the cable and interfering with it. Check to make sure you have a good ground connection on the cable and the power cables connections. I hope this information helps you with your problem.
Posted on Jun 06, 2009
  • 187 Answers
SOURCE: panasonic th-42pd50u no pic no sound but pwr light on
Replace the mainboard, it is going to be damaged, there is a chance it could be the powerboard but it is quite remote to take into consideration.
Posted on Jun 13, 2009
Bought a Panasonic plasma tv. Th-42PW5. Had to run thru VCR due to lack of connections available. Picture is entirely green. What can I do?
sounds like the cable or connections are not good. Your not getting all the signals or the tv needs adjustment/recalibration (if it is good).
does it have a test or demo mode to see if it is good?
some possibly useful links:
. Google
Mar 25, 2017 | Panasonic Televison & Video
I purchased a used Panasonic Plasma TV TH-42Pw5. I finally got a picture by hooking it up through a vcr, but the color is completely green. When using the remote instruction colors are varied. HELP!
usually a single color is caused by a bad connection to the display I would guess that a connector inside the TV has come partially loose causing this this is quite common on the computers at my work due to vibration before taking the TV apart I suggest replacing the external cables to the VCR
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
How to connect headphones to this tv.
The only way to accomplish this will require an external amplifier.
Connect the program out to the input of the external amp and use the headphones from there. Disconnect the speakers or turn them off in the audio menu.
Hope this helps,
Dan
Jul 11, 2010 | Panasonic TH-42PX60U Television
I have a Panasonic th-42pw5 plasma screen
most likely it is the buffer boards and the z sus
Feb 12, 2018 | Panasonic Televison & Video
I need a replacement tuner box for panasonic th-42pw5 plasma panel.can you help
It is Still Available with Some Vendors. You could Purchase it from :-
http://www.digitaldirect.co.uk/panasonic/tu-pta600b.html?referredby=WINDOW
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1421
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 08, 2010 | Panasonic TH-42PWD5UY 42 in. Television
I have a panasonic TH-50P V600 TV, the sound in
by any chance do you have the set in suround sound if you do change it back to stereo.. and try that most of todays set have poor sound and tiny speakers. because so many people connect there set to a theater system
Dec 04, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic th-42pd50u no pic no sound but pwr light on
Jun 12, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Dec 14, 2007 | Panasonic SC-HT720 System
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
