Question about Dacor 30-in Convection Double Electric Wall Oven Black MOV230S
Dacor double wall oven model MOV230S where is reset button
Error codes L43 relay board came on with beeping. Now there's a L60 cooling fan code on.
5 Suggested Answers
vitg55
  • 78 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
localwonder
  • 6784 Answers
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Posted on Aug 01, 2009
  • 523 Answers
SOURCE: ECS227 Epicure Electric Double Oven: I have a Dacor model # CPD227R double convection o...
replace touch pad
Posted on May 06, 2010
SOURCE: l43 relay board message on dacor millenia double oven
HAS ANYONE SOLVED TEH L43 RELAY BOARD MESSAGE?
Posted on Jan 04, 2011
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Dec 31, 2009 | Frigidaire 27 in. Electric Double...
I had an F1 Code on my Jenn Air WW2780B Double Wall Oven, and turned both ovens on to heat up, which they did, and the F1 code never came back after that... so far. Could it be fixed?
Hi, This code is an indication of a fault that exist within the actual relay board. It is malfunctioning at this time, and should be replaced asap, if possible.This relay board is located inside the unit, mounted on the cooling fan shroud. Once replaced, the F1 code will be cleared automatically.
Relay board part number: Y04100261
Click here to view an exploded diagram of the cooling fan shroud, with relay board attached. The relay board is labeled number 9, and the shroud is labeled number 1
Oct 27, 2009 | Ovens
Dacor single oven flashes an F2 error code and won't stop beeping!!!
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor error codes
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Apr 09, 2008 | Dacor ECS230 Epicure Electric Double Oven
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
Feb 05, 2007 | Dacor Millennia MOV130 Electric Single...
Dacor 30-in Convection Double Electric Wall Oven Black MOV230S Logo
161 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
