Question about Pool & Spa
Magnetek century spa pump
Volt 220/115 AMP 11.3 / 22.6 HP Part nr 7 181579-02 Pump has stop working. Can it be rebuilt? If so is it worth doing or is there a replacement pump you suggest? If replacement how much. Or if able to rebuilt were. I live in Lancaster pa
SOURCE: High Ringing Noise
Sounds like it just needs lubricating. It's probably dry seals rubbing against the stainless shaft.
Bad bearings usually make grinding noises. Replacing bearings can be a DIY job, but not a teriffically simple one.
Posted on Apr 21, 2009
  • 93 Answers
SOURCE: I have an A.O.Smith Century Pool & Spa motor
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
Posted on Jun 20, 2009
  • 279 Answers
SOURCE: Spa 2 go pump stopped. Need to replace the pump?
Is the motor running? If it is there could be a coupler broken. If the motor is not running, it could be the problem. If the motor is not running, is there power to it? If not, it may be a broken switch that controls the motor. If the motor has power but not running, then probably the motor, its starting system or bearings. Bearings? Yes, they may be frozen and or dry. Dont spend a lot of money until you have the problem located. Good luck...Lee
Posted on Nov 13, 2009
macdirk
  • 116 Answers
SOURCE: Need to replace pump Impeller on A.O. Smith
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 12, 2010
  • 1796 Answers
SOURCE: I have a Vita spa
Hi!!
If the motor does not run, the water will not circulate and wont't get hot. I don't believe the wiring or breaker are at fault either, just to be on the safe side, check for tight connections all around, specially the ones coming from the breaker to the motor.
The problem with the motor is that is not getting enough juice to start up, so the start capacitor is most likely to be at fault and needs to be checked, if you don't have a multimeter with the capacitance function, just remove the capacitor and have it checked at the store. You can get capacitors at any appliance parts, electrical and most hardware stores. You can also get a motor start up kit for under $15 to solve this problem. Wiring instructions are included.
The capacitor is usually located on top of the motor, remove the metal casing to access it, before removal, take a picture of the wiring so you can hook it up the same way.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Posted on Feb 18, 2011
My century magnetek pump10-165200-06 is alarming with relay code appearing, would like to know how to change out relay
Changing the relay is really quite easy. Once you have located the replacement relay and have it there to install.
Remove the old relay wires one by one and install them one by one onto the new relay thereby preventing any chance of wiring it incorrectly,
US Parts Center
May 22, 2014 | Century New Magnetek Pool Spa Pump Motor...
Are there electric brushes in motor
It depends on the kind of motor you have. Most do not have brushes. Most pool/spa motors have windings and bearings.
Rod
US Parts Center
Apr 14, 2014 | Century New Magnetek Pool Spa Pump Motor...
Century 1081 Pump
if leaking probably ruined bearings just replace whole pump
May 16, 2013 | Century New Magnetek Pool Spa Pump Motor...
Capacitor type
take capacitor to electric supply store to match up
Apr 20, 2012 | Century New Magnetek Pool Spa Pump Motor...
Plugged pump in and heard it kick on but it wont turn over. Help!
try spinning motor by hand from back then try again if not replace
Oct 07, 2010 | Century New Magnetek Pool Spa Pump Motor...
Pool & Spa Logo
125 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
