Question about Garden
Bunton mower how to adjust drive belt on a 52 inch bunton with a variable speed pulley
  • 40 Answers
SOURCE: Belt changing information
http://manuals.mtdproducts.com/mtd/public/list.jsp#
Posted on Mar 11, 2009
  • 376 Answers
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
bobthebulldo
  • 67 Answers
SOURCE: Mower takes too long to pick up speed
check that the belts are at right tension as they could be sliping slitly and that is why it is taking the time to kick in ,try tightening the belts a bit
Posted on Oct 17, 2009
vincob
  • 718 Answers
SOURCE: variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Posted on Jul 26, 2010
rycgl
  • 1545 Answers
SOURCE: i need to find the
You can download an owner's manual from this link. It may or may not have the belt routing schematic, but I'm betting it does. You will need to input the model number of the machine you have to enable the download.
http://cgcequip.arinet.com/scripts/EmpartISAPI.dll?MF&app=CGC54&TF=EmpartWeb&partner=CGCSB&lang=EN&loginid=CG999997&loginpwd=2006CGC1030
This long URL reduced to size is:
http://tinyurl.com/3qgjlgd
Posted on Apr 15, 2011
How do I loosen a rusted variable speed pulley to get a V-Belt on it.
with a torch heat it up till till it hot use puller pull it free put anti seize re install pulley
Sep 04, 2014 | Garden
Sears mid engine 30 inch breaks drive belts
for a belt to wear on the inside means that the pulleys are badly worn or you have the wrong section belt in use.V belts never work on the bottom of the pulleys.For a belt to operate properly the top of the belt should be just above the edge of the pulleys. For variable speed pulleys the belt should never make contact with the bottom of either pulley. Measure across the top of the flanges of the pulley and that will be the first number of the belt you require ie 14v1406 will be a 14mm wide belt and 1406 mm in circumference. or 3/8 41 will be 3/8 across the top and 41" long
Jun 14, 2013 | Craftsman Garden
Adjusting variable speed pulley in riding lawnmower
check the other variable pulley on the other end
Apr 06, 2012 | Garden
I just replaced the drive belt on my Troy built auto transmission Bronco 42" riding mower, and now it goes a lot slower. The belt seems to be routed correctly
The bronco is a variable speed mower from what I remember. There is a belt that goes from the crankshaft to a variable speed pulley and another belt from the variable to the transmission. If your 1st belt is too long it will never get up to speed. Do you have to push the pedal down further now than before to get it to move. ? If so your main belt is too long.
Jun 05, 2011 | Mtd Drive Belt 42"
Belt jump off the drive pulley
I don't have this kind of mower. But I was faced with the same problem recently. I got my belt back on by taking a large wrench and affixing it to the bolt head holding the pulley which you want to slip the belt on. Hold the belt firmly against the pulley and turn the wrench and the belt in the grove will walk around the pulley until it slips in place.
Apr 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Oct 15, 2009 | Mtd Garden
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
Variable speed belt issue
Get your model and serial numbers from under the seat. Then go to the MTD website where you can download the owners manual which should show the belt diagram.
May 24, 2009 | Mtd Garden
Belts slipping and breaking
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
May 15, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
