Question about Mintek DVA-8700 System
Funtion botton won,t change funtions - Mintek DVA-8700 System
My volume and channel not moving
I presume that systems used to work OK and you are using the remote. Try the bottons on the TV itself. If they function OK than your problem is the remote. If no funtions work, replace batteries. If only volume and channel are failing than the remote button pads may be dirty. Repair of the remote is dicey but the risk is low. You may need to replace remote.
Nov 30, 2014 | Televison & Video
HT-E5500 FUNTION(SOURCES) KEEPS CHANGING ON ITS OWN
Why does the HT-E5500 FUNTION(SOURCES) KEEPS CHANGING ON ITS OWN
Sep 06, 2013 | Samsung HTE5500
Emprex wt323 power supply
Should be the fault to its main digital board. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 18, 2013 | Televison & Video
Radio works just the buttons to switch from cd to radio to aux do not
What brand Model, and how old is the radio?
Anyway, same botton or a separate one?
When you select Your sending a pulse to a funtion switch circuit.The
switch circuit may not be working, needs repair.
Oct 31, 2012 | Cars & Trucks
Dryer won't restart breakers ok door switch funtional but when i press srart button just buzzes......... suggestions?
Reach inside and try to turn the drum. If it is stiff you could have a bad roller or support bearing depending on your model. I have all kinds of dryer manuals HERE
and Here
Jul 07, 2012 | Dryers
Laptop hp pavilion dv2000, problem keyboard botton 5,6,- not funtion
you could by a new keyboard like on desktops or it would be cheaper to just buy a num pad
Jul 03, 2010 | Computers & Internet
I installed the vga drivers but i dont change any
Download your Drivers From this link.
Select your operating system and download.
Dont forget to rate !!!!
Thanks
Mar 10, 2009 | Computers & Internet
The function key is stuck on my Dell laptop
Just press the funtion key and the Numberlock key
FN + NmLk (Usually on the same key as delete)
Please rate this a fixya
Feb 08, 2009 | Dell Inspiron 1501 Notebook
It is asking for code
You are referring to the theft code, correct?
Aug 01, 2008 | Kenwood Car Audio & Video
16 people viewed this question
Top Mintek Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mintek Audio Player and Recorder Expert? Answer questions, earn points and help others
