Nordyne jt5bd-024k 2.0
The fan not turning but I can hear the motor
3 Suggested Answers
  • 659 Answers
SOURCE: I need a wiring diagram for the fan motor
http://www.nordyne.com/literature/710235a.pdf
This is to your unit. Good luck!
Posted on Apr 09, 2009
heinzhvac
  • 229 Answers
SOURCE: I have a nordyne FT4BD-024K. Thermostat is fine. I
If you have 24 volts at the transformer check the circuit board there is a 3 amp fuse on there its like a car fuse see if it is blown. Otherwise if you have 24 volts everywhere it has to be the t- stat because thats what kick the a/c on directly from t - stat. let me know
Posted on Jun 28, 2011
I need the wiring diagram for a Nordyne GS3BA-024KA condenser
3 wires for compressor, 3 for fan. 2 comp. wires go to the top of the contactor, the remaining goes to herm terminal on capacitor. 1 fan wire goes to the top LEFT of contactor, remaining 2 go to com and fan on capacitor. You will then have 1 wire left that goes to the com on the capacitor and should go back to the top RIGHT of the contactor. NOTE: IF YOUR FAN MOTOR IS RUNNING BACKWARDS (MEANING AIR IS NOT BLOWING OUT OR UP) swap the to fan motor wires on the capacitor (fan and com) this should reverse rotation. ALWAYS REMEMBER TO TURN POWER OFF AND DISCHARGE CAPACITOR BEFORE TOUCHING WITH INSULATED SCREWDRIVER. Good Luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 22, 2017 | Heating & Cooling
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
Need electrical schematic for Intertherm P3RA-024K
Hi Val
check this out maybe it helps.
http://www.manualslib.com/manual/507003/Nordyne-P3ra-030k.html?page=9#manual
Dec 03, 2015 | Intertherm P3RA-042K Air Conditioner
Nordyne Split System Blower Won't Start
It's the fan motor. A relay problem would cause the motor not to run at all.
May 08, 2017 | Heating & Cooling
I have a nordyne FT4BD-024K. Thermostat is fine. I get the 24V on the board in the outside unit, but the unit does not kick on in either heat or AC mode. Will kick on if I manually push on the relay...
Jun 28, 2011 | Heating & Cooling
Installed new stat and fan won't come on in heat made or cool mode.
Turn the thermostat switch that says fan on------auto to on an see if the fan comes on ,if don,t then the problem was the circuit board or find power wires going to the fan motor and jump it out to see if the fan motor is good or bad. then if it starts, then you,ve know ,you,ve eleminated the fan motor and its the circuit board...
Dec 08, 2009 | Intertherm P3RA-024K Air Conditioner
Need wiring diagram to wire a Gibson GB5BM-T42K-B to a NORDYNE JT5BD-042K
you just need to follow the diagram that came with your new unit but its probably the exact same considering nordyne makes gibson andall thier parts are universal
Sep 10, 2009 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
