Question about Galtech Round Crank Patio Umbrella - Cream 9
Do i fix my steel cable like the videos that use rope?
Assembly Manual
Nothing to assemble in this kit:
Product Description Universal tent assembly and repair tool kit
1 mallet with white rubber head
1 guy rope: 15 m , colour Grey/Black
1 guy rope tightener
6 adjustable fasteners for ropes: 3.8cm x 1.3cm x 0.4cm
4 round closed hook head, zinc plated steel stakes: 23cm x 3.9mm
4 standard zinc plated steel stakes: 27.5cm x 6.5mm
4 zinc plated steel stakes: 23cm x 2.0mm x 1mm
4 zinc plated steel stakes: 28cm x 2.0mm x 1mm
8 nylon/elastic rubber rings: 29cm x 0.4cm
2 self-adhesive pathces: 7.5cm x 0.55cm
Oct 30, 2013 | The Camping Equipment Company Universal...
Clutch cable adjusters
Bowden cables like your clutch cable work on the law of the lever. Think of lifting up a heavy weight hanging on a rope using a lever balanced on a fulcrum. The rope is in tension and the fulcrum is in compression. To adjust the point of lift you could either vary the length of the rope or adjust the height of the fulcrum. The outer sleeve of your clutch cable is made out of plastic-coated steel, square-section wire and is resistant to compression forces along its length. This outer sleeve works as your fulcrum and, because it is flexible, lets you put it where it is needed - at the end of your handlebar. The cable inner is like the rope in the lever example and resists only stretching forces. It is threaded down through that snaking fulcrum back to where control movement is needed. The cable adjusters let you fine tune the length of the fulcrum, and therefore the lift range of the inner cable.,,,
Nov 10, 2008 | 2005 Enfield Bullet 500
Nov 10, 2008 | 2002 Cannondale C 440
Nov 10, 2008 | 2008 Buell XB12XT
Nov 10, 2008 | 2000 Buell S3T
Nov 10, 2008 | 2006 Bimota Tesi 2D
Nov 10, 2008 | 2006 Bimota DB5 Mille
Nov 10, 2008 | 2008 Beta RR 450
Nov 10, 2008 | 2008 Beta Alp 125
Nov 10, 2008 | 2006 Benelli TnT Titanium
Galtech Round Crank Patio Umbrella - Cream 9 Logo
54 people viewed this question
Top Galtech Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Galtech Garden Expert? Answer questions, earn points and help others
