Question about Haier HPRD12XC5 Air Conditioner
Portable air conditioner
Red Caution light blinking
5 Suggested Answers
kaycee71
  • 37 Answers
SOURCE: I have HAIER HPAC 99ER Portable air conditioner
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
Posted on Aug 28, 2009
  • 10865 Answers
SOURCE: My portable air conditioner Haier started linking
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Posted on Jul 06, 2010
Testimonial: "There was dust covering the entrance of a tube where the water used to flow and evaporate, it was right beneath where the air filter is located. Removed the dust and is working fine again. Thank you"
heatman101
  • 43501 Answers
SOURCE: air conditioner wont turn on.
Have you tried to pull the plug for a few minutes and then plug it back in and retry???
Sounds like it cutout on a safety of some type...if it continues then find out what is wrong and why it is cutting out..
If cycling the power does not fix it then the board could be bad...
heatman101
Posted on Sep 03, 2011
  • 4736 Answers
SOURCE: I have a commercial cool
Karen, the flashing red light indicates that the water collection tank is full and needs to be emptied.
You can finds the drain plug on the rear of the unit just above floor level.
It can either be drained into a low sided bowl or pan capable of holding 1 quart of water. or you can disconnect the exhaust hose(s) and roll the unit to a floor drain or outside to drain it.
Hope this helped you and thanks for choosing FixYa.
Posted on Sep 06, 2011
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
2003 vw golf tdi transmision wont shift into overdrive and a red caution light keeps blinking
Have you checked the Fluid Levels?
Have you checked the OBDII Codes?
It sounds like you are having either a LOW FLUID or a Fault inside your Transmission
Apr 08, 2013 | Cars & Trucks
2oo3 vw golf tdi 4 speed automatic wont shift into over drive and red caution light keeps blinking
Is there a Push Button to take your Transmission out of Overdrive? Are you pushing the RPM?
IT sounds like you need to put a Scan Tool on the Vehicle to see what is going on and giving you the Caution light
Is there a way that incan by pass the lid light blinking
CAUTION CAUTION CAUTION CAUTION CAUTION CAUTIOON
normally this indicates lid not closed but possibly open circuit switch if washer is working cant be the switch to bypass the switch can be tecnical as you have a live feed to switch then switching wire fron switch te neon bulb then other bulb wire goes back to circuit so do away withe the switching wire from switch to bulb then live switch wire to other wire on buld that goes back to the circuit then switch has gone and the bulb no more flashing light
Aug 12, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Engine warning icon on my dashboard indicates emission problem can I still drive my car until repaired
As long as the light is yellow and not red you are fine to drive . The yellow is just a caution light . If any red lights come on thats when you need to stop or not drive it
Aug 05, 2012 | Saturn Cars & Trucks
TV no longer powering up. Red power light blinks 10 times, stops, then repeats. Tried holding down the power button, turning off the tv for a while, plugging directly into wall instead of surge...
Bad or blown capacitors. Look on circuit board for domed, bulging or leaking capacitors. USE CAUTION!! high voltage capacitors can electrocute you. They should be properly discharged before working on circuit board
Jun 28, 2011 | Panasonic Viera TH-46PZ85U Plasma TV
Some keys on the keypad are not working, like the del key and the letter p
Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653
Feb 19, 2011 | RIM BlackBerry Bold 9000 Smartphone
I have the smae problem how do I clean the bulb
We have the repair guide for the HP Laserjet "scanner warming up" error posted on our web site at:
www.ccl-la.com/hplj3330.htm
I hope this helps you, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | HP LaserJet 3330 All-In-One Printer
Does not initiallize and caution and paper light blinking
Read this HP support page:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1845551&prodTypeId=18972&prodSeriesId=1845551&objectID=c00763669
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 03, 2009 | HP LaserJet P2015 Printer
No picture blinking stand by light
I hve worked on a number of these units , your description is typical of a shorted blue picture tube. The protection circuits in the tv detect that there is a problem thus shutting the unit down to prevent further damage. Sony had a bad run of picture tubes in this series. The replacement cost of the tube is about $250 plus labor. My estimate would be for the repair about $400-500 depending on where you live and how honest your local technican is. I will caution you however, that you could replace this tube and the red or green could go. These would not be covered by the technicians warranty. When these sets are working, they have a superb picture and it is easy to get lured into fixing them. Scrivitron
Jun 13, 2007 | Sony KP-51HW40 51" Rear Projection...
Haier HPRD12XC5 Air Conditioner Logo
20 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
