Question about Husqvarna Garden
Husqvarna 232r my husqvarna 232r brush cutter cuts out when warm for no reason then wont start sometimes once warm
4 Suggested Answers
  • 124 Answers
SOURCE: Muculloch brush cutter wont start. No spark.
If you have correctly diagnosed the problem as no spark, you will need to replace the ignition module. Unfortunately McCulloch dealers and McCulloch parts are very hard to find these days. If yoou do not have a dealer in yoour are who has the part you need, contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Posted on Sep 22, 2009
  • 4088 Answers
SOURCE: My Husqvarna 232R brushcutter pull cord will not start
There should be several 'dogs' exposed after removing the starter assembly. These 'dogs' should rotate into the flywheel nut when the cord is pulled causing the engine to turn. Check with a Husky servicing dealer for parts. Good luck!
Posted on May 28, 2010
  • 144 Answers
SOURCE: i 've had this brush
Hi John, this is probably a carburetor adjust issue, but it could be something else like an air leak, plugged air or fuel filters or lines. A possibility could also be venting of the fuel tank. This is usually done by a one way valve in the gas cap. The carburetor itself could be causing this problem, and might need cleaning or a carb kit. Try adjusting the mixture screws that could be the problem. When adjusting needle screws turn 1/8 of a turn at a time. Start by adjusting the low (idle) speed mixture screw 1/8 turn out (counterclockwise) to add more fuel to the mixture (make sure you remember the start position). Start your brush cutter and see what happens. If you have to, do that procedure 4 or 5 times. If not any better, return the screw to it's starting position. You might try turning the screw in (clockwise) a few times and see what happens. For your info (the manufacturers suggest to adjust both the high and low mixture screws 1 turn out from a lightly seated position as a starting point to adjust carb. This is very often just right, but if adjustment is necessary it is usually not by much). If the low speed screw adjust has no results, try the same with the high speed screw. I hope this helps a little bit. Get back to me if you have any questions. All the best and good luck.
Posted on Feb 15, 2011
Put too much oil in the Husqvarna brush cutter. It smoked the first 30 minutes of use, then died and now will not start. Did I ruin it. What needs to be cleaned or checked. It uses straight gas.
You state you put too much oil in the cutter. then you state it uses straight gas. All the cutters I ever used had a mix of 2 cycle oil and gas. Usually when you place too much oil in the mixture it fouls the spark plug and could cause carbon build up. If the plug has oil on it it will never ignite. Do not put straight gas in the fuel to try to burn off the oil you will only make matters worse. Clean the plug, drain your fuel and start from scratch. If it still fails to start, you need to bing it in to a small engire repair shop. Good Luck!!
Aug 11, 2014 | Garden
Husqvarna 235r brush cutter starts fine when cold but won't start when hot
If it has spark and fuel then it may be worn, causing low compression and too weak to start. .
Jun 15, 2014 | Husqvarna 323R 24.5cc Straight Shaft Bike...
Husqvarna Mega Quilter. After using the thread cutter the bobbin thread will not pick up to continue sewing.
sometimes the cutter doesnt leave a long enough tail to start sewing, and the needle wont pick it up, use a diferent thread in bobbin, sometimes thats the issue, or manually extend the thread from the bottom and then start sewing, it will pick it up then
Oct 21, 2013 | Husqvarna Viking 1
My brush cutter keeps cutting out why
Is your fuel mixed correctly.? Do you still have good compression.? Is the choke leaver stuck on.?
May 21, 2012 | Stihl String Trimmer Brushcutter Service...
Husquvarna 460 rancher 20" bar all new including
The normal reason for a saw to cut to the left, or right is because the cutters have been sharpened more on side than the other, they are now longer on one side, this then sends the cut off to that side. Measure the cutter lenghts, take the correct file and shorten the longer cutters
Mar 06, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
May 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
The selective thread cutter not cutting thread.
You need a new blade in the cutter. It is a simple repair job, but needs to go to the repairman for it to be done.
Feb 28, 2010 | Husqvarna Designer I
My viking serger 905 wont cut
Sometimes the blades need to be adjusted. Lower them all the way manually to the bottom. The cutters if you look on the side should meet. If they don't' meet or if there is a small space then the upper cutter needs to be lowered.
There are screws that hold this in place. You might need a man to help since the screws on my machine are very tight!
Nov 05, 2008 | Husqvarna Viking 1
Garden Logo
24 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
