Question about Dryers
Bosch Instruction Manual WTZ11310
How do I unstack the tumble dryer?
  • 55 Answers
SOURCE: Whirlpool AWZ 3303 Tumble Dryer
http://www.whirlpool.co.uk/ifudocs/501930700361GB.pdf
Posted on Mar 25, 2008
  • 3 Answers
You can usually download from Whirlpool website
Posted on Jul 10, 2008
SOURCE: Bosch WTA 3100 Tumble Dryer ON/OFF switch
The on/off switch is combined with the door release switch in one item - part number 154145 (a little over £20) and my problem was the door interlock bit had failed. The following worked for me :
Plug out, remove top panel, and open door + look up at switch panel - you see 5 slots under the switch panel (the 2 outer ones are mostly covered by the main front panel). Start at either side and work across, using as wide-bladed a screwdriver as will fit across the slot width : put a wood block under blade as a support and lever bottom of panel towards front - each has a plastic pin behind pointing towards the rear, held by a spring clip. Each will pop clear and when all are unclipped you rotate the panel outwards from the bottom edge, taking the timer knob and its drive linkage with it. To get switch out I removed the door and the screws around the main front panel - one is hidden behind a cover plug below the access port (to gain access to bottom screws on main panel, lever the bottom panel outwards along its top edge).
Posted on Sep 08, 2008
  • 686 Answers
SOURCE: Does the Bosch Tumble Dryer WTA3003GB/01 have a trip reset button
YOUR DRYER HAS A FUSE AND NEEDS TO BE CHECKED. SEE IF IT IS LOCATED SOMEWHERE WHERE THE POWER CORD COMES IN AT. IT SHOULD BE CLOSE TO THE MAIN POWER COMING IN OR MAYBE EVEN IN THE CONTROL PANEL AREA.
Posted on Apr 10, 2009
  • 7 Answers
SOURCE: Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
How do I detach my Bosch drier from yhe stacking kit as I need to replace the drier
most model have some bolts or screws to keep dryer safe on top of washer
just remove bolts and screws and pull back the dryer
Feb 11, 2015 | Bosch Washer And Dryer Stacking Kit...
Bosch stacking kit installation manual
Go to manufacture web site and download need documents
Oct 03, 2014 | Bosch Washer And Dryer Stacking Kit...
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
Tumble dryer manuals
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
When you open the link, half way down the page you'll see the following, "click here to download instruction manuals (launches in a new window)"
When the new window opens, type in "WTA3606GB" in the search box and press<GO>
The manual will be in a pdf document format. You can download it or open it and then save it- the site is free.
Dec 04, 2013 | Dryers
I would like to download an instruction manual for my bosch tumble dryer wte6920gb. Please can you advise.
You can find your manual here: http://www.bosch-home.co.uk/download-product-manuals.html
May 04, 2011 | Microwave Ovens
I need the user manual for Bosch WTL 4613 electronic tumble drier
0027 516659 Instruction manual de,nl,fr,es,en,pt,it 7.80 USD Unfortunately my search on-line for this manual came up short. You can order one directly from bosch at their appliance website. The cost is $7.80, the part number is 516659. Weblink: eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTL4613%2f01&ESHOPTYPE=A">http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTL4613%2f01&ESHOPTYPE=A
Jan 30, 2011 | Bosch Dryers
I have a Bosch tumble dryer but no instruction manual, please can you e-mail one on whittaker98@btinternet.com or post one to me at 2 Georgian Court, babbacombe Road, Torquay TQ1 3TF. Thank you. Lynn...
Our Bosch WTA2000 tumble drier dries the washing properly but is very noisy. How do we know what to replace, eg a belt, or whatever please?
Julie Welt
Mar 08, 2010 | Dryers
Dryers Logo
57 people viewed this question
Top Dryers Experts
