Question about Pioneer DEH-P690UB CD Player
Radio wiring diagram
Dont have pioneer harness need to know what each pin goea to
etirbynnor
  • 655 Answers
SOURCE: Need wiring harness color coded diagram for pioneer dehp6800mp.
Hello randscates,
Here's a link to the manual. The wiring color code for the supplied harness is on page 78. The diagram is rotated 90 degrees clockwise. I recommend that you download the PDF and print out the page you need.
Hope this helps.
Posted on May 16, 2009
  • 436 Answers
SOURCE: i dont have a wiring diagram for the 16 pin plug
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Posted on Aug 25, 2009
  • 68 Answers
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Posted on Nov 17, 2009
ABKSeeker
  • 69 Answers
SOURCE: need wiring diagram for pioneer deh p3900mp
here is the link to your manuals:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-P3900MP.Support
see pg 2 of other manual for wiring diagram
Cheers!
Posted on Feb 16, 2010
I don't have a wire harness for my Pioneer car radio DEH 780 MP and it's a 14 pin iso connector I need the diagram so I'll know what color wire to put in the right place for it
Walmart and some auto parts stores have installation kits that have the plugs already wired for your radio and vehicle harness. You simply connect them together.....no cutting or splicing.
Mar 16, 2016 | Pioneer Car Audio & Video
I need help with wiring diagram for a chevy tahoe 08 radio installing a pioneer avh-x3700bhs I did buy a wiring harness but it doesn't have all color wires on it
Just match wire purpose on both diagrams. Wire color may or may not match.
EXAMPLE: Right Front Positive (RF+) and Right Front Negative (RF-) on the harness is purple (RF+) and purple/black (RF-). While on the radio it's white (RF+) and white/grey (RF-).
Feb 23, 2015 | Pioneer Car Audio & Video
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Installation wiring diagram??
No need to guess what wires go where. Buy a wiring harness for your specific year, make and model.
You make connections from your pioneer harness which are all marked, to the Harness you will purchase for your car. They cost about $20 and can be purchased at most autopart stores, or major electronic retailers.
Once you make the connections from the pioneer harness to the harness specific for your car, simply unplug your factory radio and plug in your newly wired one.
Jan 25, 2010 | Pioneer DEH-2300 CD Player
Need to replace the original radio on a 1999 Ford Ranger XLT (F87F-19B132-AB) and cannot identify pin connections to install a pioneer DEH-1100MP. . Need the wiring diagram for the harness connection to...
buy a adapter from local car audio store if not look in a haynes book they should have one just sitting around local auto parts store take a pic of it if u dont want to buy or write it down
Oct 03, 2009 | Pioneer Car Audio & Video
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
May 21, 2009 | Pioneer DEH-1500 CD Player
Dont know the wiring diagram
Positvie is red, ground is black, and or black with a white stripe. the yellow wire is also a positive wire, it is the memory wire which should be hooked to something that will always be hot, even when the key is completely off. If you have a power antenna, that is controlled by the blue wire
May 03, 2009 | Pioneer DEH-1000 CD Changer
Got a new deh-6000ub and wire harness for honda accord dont know how to install the harness
You need an installation harness. You can get them at most anyplace that installs car stereos. Once you have the installation harness for your car, you just match up the colros of the wires on it to the same colors of the harness for the Pioneer. Make sure that each wire is insulated from anything by using some electrical tape and make sure they all have good connections. Strip away close to about an inch on each wire and then twist them together and then tape them good. After all the wires have been connected, all you need to do is plug the Pioneer harness into the Pioneer radio and then plug the installation harness into the factory wire harnees connector in the car. If you have any wires that do not match up in color, you can normally leave then not connected to anything, but make sure they are insulalted with electrical tape. Most all the wires should say what they are for. Matching the colors is the easiest way to do this.
Let me know if you need more help. I can always give you a detailed wiring of the Pioneer. I do not have the wiring diagrams for the car though.
Jul 20, 2008 | Pioneer Car Audio & Video
Pioneer deh 2300
buy a build ur own connectr at radio shack use all the pins then just figure out what wire goes to what
Mar 29, 2008 | Pioneer DEH-2300 CD Player
Pioneer DEH-P690UB CD Player Logo
18 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
