Question about Samtron SV-C20 Video Cassette Recorder Player VCR
Need universal code for Samtron SV-C20 VCR - Samtron SV-C20 Video Cassette Recorder Player VCR
Codes for a samtron sv c-90 vcr?
Code(s) would be in a compatible remote.
Nov 12, 2016 | Televison & Video
Codes needed for remote
What brand of (universal?) remote are you trying to use to operadte your Samsung DVD/VCR combo?
Dec 24, 2012 | Samsung SV-DVD440 DVD Player/VCR
Missing remote
Buy a universal remote. They work very well!
Aug 18, 2012 | Samsung SV-DVD50 DVD Player / VCR Combo
Need vcr codes for samtron vcr to program universal remote
I did use the Samsung code for my Samtron VCR...in fact one code worked for my TV foo....worked perfectly
Oct 09, 2009 | Televison & Video
Samsung SV-5000W VCR. Voltage regulator?
This unit has a universal power supply that automatically detects proper voltage. No buttons or adjustments required, just plug her in.
Jan 04, 2009 | Samsung SV5000W VHS VCR
Need remote control code
Your universal remote should have included a handbook that has some of the codes of many products. Samsung will be on this list and offer a few or dozens to try. If those don't work (after trying each one! so fun!) it has several paragraphs on how to use the remote in tandem with your player to search and 'lockin' the code. I have found the lower priced Universal remotes ($10.) do not always solve the problem. I took the cheaper one back and got the next step up for $20. it works like a charm. You never really 'learn' the number because you are randomly hunting for the code that either turns your equipment on or off. Does this help?
Nov 20, 2008 | Samsung DVD-V5500 DVD Player/VCR
Need codes for rca universal remcon to emerson vcr and need codes for emerson vcr and coby 224 dvd
Try these codes for the emerson:
Code 003 for Emerson VCR Code 007 for Emerson VCR Code 012 for Emerson VCR Code 014 for Emerson VCR Code 015 for Emerson VCR Code 021 for Emerson VCR Code 024 for Emerson VCR Code 025 for Emerson VCR Code 026 for Emerson VCR Code 029 for Emerson VCR Code 031 for Emerson VCR Code 032 for Emerson VCR Code 033 for Emerson VCR Code 038 for Emerson VCR Code 041 for Emerson VCR Code 054 for Emerson VCR Code 065 for Emerson VCR Code 116 for Emerson VCR Code 130 for Emerson VCR
and I wasn't able to find any for the dvd player :/
Jun 13, 2008 | RCA Universal Remote Control
CODES
I used some of the codes for Samsung and one of them was a match for my Samtron vcr.
May 12, 2008 | Televison & Video
I need a code to program my Directv remote to control my Samtron vcr.
If you still have the manual for the remote, try using the automatic code search.
May 12, 2008 | Directv RC32RFK Remote Control
Mbr3447 remote code for samtron vcr
Up untill a few years ago they used to make a lot of universals with a "learning" function, that you aim the thing at a certain device untill it figures out the right code for it. I read that the technology was bought since so you dont see those quite as often in the market. ok, if yours is a learning uni, here's a tutorial on how to fix it, in general terms since it varies between remotes: If you cannot get the instructions - most "universal" remotes have a "code search" feature. Usually this involves hitting the "program", "select" or "function" button, then pressing the device button ("TV", "VCR", "AUX") then repeatedly pressing the "power" or "channel up" button until the set responds. The remote will cycle through each of the codes (01, 02, 03, 04) sending the "power" command for each. When you hit the right code - the set responds. When the set responds, stop and then press the "program" or "function" button to enter it (which button varies between mfgrs). If you count the number of presses - that should be the code (12 presses is "12" or "012" - or it could be 11 if the codes start at 00). If you do not have a "program" button (it might be hidden), then you may have to instead hold the function (TV, VCR, Cable) button down for a few seconds (until the light blinks). The usual manual sequence is: 0 1 2 It might also be: 0 1 2 If no program button: 0 1 2 Some remotes use a two digit code, some use three. It'll take quite a bit of trial and error without the manual. you can try getting the codes from the manufacturer, go to their site and see if you can figure anything out there... good luck
Jan 19, 2006 | Zenith MBR3447 Remote Control
Samtron SV-C20 Video Cassette Recorder Player VCR Logo
Top Samtron Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Samtron Audio Player and Recorder Expert? Answer questions, earn points and help others
