Question about LG Televison & Video
Need EEPROM code for LG HT805VM
My LG HT805VM stopped reading DVDs It can still read everything else (VCDs, CDs....) I read somewhere that the Prom code could be off I accessed the place where I can see/change the code (by pressing Pause and 1 4 7 2 on the LG "bootup" screen) Right now it's: f7 00 45 b4 00 00 80 00 bb 00 Does anybody know the correct one for this model?
  • 297 Answers
SOURCE: DVP5140 only reads DVDs
The DVD player have two lenses.;cd and dvd lense,the cd lense needs a little adjusment so can read again..
Posted on Jun 19, 2008
  • 4 Answers
SOURCE: Panasonic DMR-EZ75V reads ''NO DISC'' for DVDs
I had a problem w/my dmrez475 and called pan @ 1-800-211-7262 and talked to John at ext 5070.
He seemed very knowledgeable and sent me an update CD. The CD fixed my problem which was in
the timer recording mode. Call him, maybe he can help.
Posted on Jan 03, 2009
  • 3 Answers
SOURCE: dvd drive cannot read cds and vcds but can read dvds only
I had the inverse problem on my unit - 7 months after I bought it brand new it wouldn't read DVD's, but would read CD's no problem -- I bought a replacement loader from LG, swopped them out myself and now works 100%.
Turned out the laser for reading DVD's had gone - they use different lasers or wavelengths or something... :)
Posted on Jan 13, 2009
  • 4234 Answers
SOURCE: sony player dvp-cx850d won't read cd or dvds. need to reset
This is not a problem that a reset will resolve. If you can gain access to the lens, try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the spindle motor may be defective. This is the motor that turns the disc. Once a disc is recognized as being loaded, the disc is spun up. If it does not get to speed fast enough, it will fail to read.
The bottom line is that without seeing the unit, I can not state exactly which scenerio you have here.
If the cleaning does not resolve the problem, I would suggest you request a detailed estimate from an authorized Sony service center.
Dan
Posted on Mar 10, 2009
  • 48 Answers
SOURCE: Change Region Codes to read all DVD's
Go into the menu, select the lock icon and press '0' on the remote 7 times, then enter the region you want ie, press 1 for region 1, 2 for region 2 etc... You can press '0'
Posted on Apr 24, 2009
Davaz900kw sony
cd's use a different laser than dvd's when playing. You would need to have the optical pickup replaced.
Jan 10, 2013 | Sony DAV-DZ100 System
Dvd drive cant read dvds but can read vcds
First of all, are you trying to read Blu-Ray DVDs? Unless your drive is made for them, it won't be able to. The same may be true if you're trying to read a dual-layer DVD. Not all DVD drives can handle them.
CDs and DVDs need different kinds of laser light to be read, and a combo drive like yours is essentially two drives in one. Sometimes a problem develops in the pickup and it can read one kind of disc and not the other. My experience is that it's usually the DVD function that fails more often. The data on a DVD is much more densely packed and harder to read.
Try making sure the discs you're trying to read are clean. If the problem is affecting all the DVDs you try, replace the drive. New drives for a desktop computer only cost around $20 to $30 and they are easy to change. In a laptop, the drive will be more expensive and maybe hard to find; in that case you may want to consider a USB external burner as a replacement. This is also an option for desktops as well.
May 20, 2011 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
I have purchased a lg ht805 dvd system and says disk error when I try to input a dvd
Do this
Go into the setup menu and then into the display setup and highlight the aspect ratio option, then select 16:9 wide (but do not press enter).
now quickly press the following keys in order '1','3','9','7','1','3',9 + enter . Write down all the details that the system information screen provides.
let me know the PROM OPTION CHEERS
Apr 10, 2011 | Televison & Video
My dvd player reads CDs, VCDs, MP3s but fails to read DVDs. What should I do?
That is the spindle motor that is weak. Try replacing the motor. Cd,mp3 vcd requires low speeds while dvd are high speeds.
Aug 03, 2010 | Televison & Video
CD / DVD ROM problem, can read cds or dvds that I create
Sounds like your need to install the codecs. Here's a good set of them: Download the full version and you might also want to check your dvd decoders,
http://www.free-codecs.com/download/K_lite_codec_pack.htm
May 20, 2009 | ASUS R1F-K049E Tablet PC
LG CD-RW CED-8120B will not read dvds
I have a LG CED 8120B in my computer right now. The reason you cannot read DVD's is because it is a CD player/burner, and not DVD.
Mar 01, 2009 | LG CED 8120B CD-RW Burner
Dvd drive cannot read cds and vcds but can read dvds only
Jan 09, 2009 | LG RH1999H DVD Recorder/HDD Recorder
DVD player cannot read the disk
Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Cds and VCDs don't require as much laser power to be read correctly. Usually when you can read CDs but not DVDs, the optics are starting to fail.
Dan
Mar 17, 2008 | Audio Players & Recorders
PLEASE HELP ME
Hi Taranum,
Are you able to view CDs/DVDs that are already burned?
Ben
Mar 02, 2008 | LG DRN-8080-B for Dell Inspiron Series DVD...
Televison & Video Logo
Computer Repairing
Computer Repairing
