Question about Motorola Computers & Internet
Rf scanner wifi disconnects when in power save
  • Official Brand Answer
  • 3,100 Answers
Hi
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads
Mark
Motorola Mobility Support
Posted on Jan 17, 2015
Why does my Samsung S3 galaxy tab keeps disconnecting from wifi?
I encountered the same problem when streamed something through wifi. The solution was in wifi (on the transmitter side) settings. Having no idea what wifi point you're using have no suggestions
Sep 02, 2014 | Cell Phones
Rci 2995dxrci2995 low rf output
you need to buy a new one or show it to an electronics engineer ...if it is good(not damaged) but you are asking how to increase its rf output power then an electronics engineer might design a custom electronic circuit with RF amplifier that provides higher output power.....also you might want to check out the rules regarding the power you are allowed to use in your country....
class AB Power Amplifier Design and Simulation
Jan 25, 2014 | Radio Communications
My dell inspiron 3520 laptop disconnects from wifi frequently
I had the same problem, wifi would periodically disconnect, and all my other wifi stuff would work fine. New computer, win8. Tried the updates none of them worked. I fixed it by going into the control panels, then selecting Device Manager, in there goto Network Adapters and click the little arrow so you can see devices there. Then right click the Dell Wireless adapter. Then click on the Power Management tab. Uncheck the box for "Allow the computer to turn off this device to save power". After I did that no more issues.
Sep 04, 2012 | Computers & Internet
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Why does my ipod always disconnect from my lynksys wrt120n router
WiFi eats a lot of power. To save energy and ensure your iPod can maintain power for as long as possible, this is often the first thing it will automatically turn off when it is not being used. No WiFi signal results in a disconnect.
I think you can disable this power saving feature, but I highly do not recommend it.
Apr 28, 2011 | Computers & Internet
Re-set key on the Motorolla MC9090 RF Scanner
Take out the battery, press and hold the power button and trigger for 30 sec and push back the battery the release the buttons.
Jun 30, 2010 | Zebra Symbol Technologies MC909X-G Series...
Wifi disconnects
I wonder if your router's encryption method is WPA or WPA2, and it is set to update its passwords periodically (like. every minute). If so, try to remove such action.
Just my 2 cents... Carlos
May 13, 2010 | Acer Aspire 5610 Notebook
I loose wifi connection immediately after disconnecting my power supply even though the battery will power the laptop without wifi for over and hour.
your laptop is set to turn off wifi on battery use. go into power settings and set your wifi to on during battery use
Jan 23, 2010 | Acer Aspire 3680 Laptop
I have hp pavilion dv4 laptop . The wifi is disabled by itself!
At the time when laptop is charging, go to power settings and disable the battery (energy) saving option, as this option starts to switch off devices one by one to prolong the discharge time.
Aug 07, 2009 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
