I've got a miele washing machine w1913 and keeps displaying stimulations active and the pc button keeps flashing. It won't work.
5 Suggested Answers
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
  • 177 Answers
SOURCE: my miele touchtronic w 3039
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Posted on Mar 02, 2010
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
richroth
  • 9472 Answers
SOURCE: My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Posted on Oct 16, 2012
Start button light flashing will not start
Hi dear.
You need to contact Miele to assist your machine repair. Description as blow. Thanks.
Start LED flashes rapidly
The drain pump (M8) is activated, level-controlled, for up to 1 h.The buzzer sounds intermittently for 2 min irrespective of its setting.Digital display: - - -
Cause
Technical fault.
Feb 01, 2016 | Miele Washing Machines
The electronic door deactivation didn't work on my last load. I opened the door manually but cannot do another load until I deactivate the locking system. Can you help me please?
Believe you have activated child lock.turn off machine at socket then whilst holding the the start button turn on power and hold button in for three to five seconds.if you have a display...look for the key symbol...if it's there then child lock is activated..follow above procedure to cancel lock and key icon should disappear.
Jul 05, 2015 | Miele Washing Machines
Miele w1913 simulation active on display when I press start/stop
Press and hold the Start/Stop button while switching the unit on with the On/Off switch.
As soon as the Start/Stop illumination ring lights constantly, after approx. 5 sec., release the Start/Stop button.
Immediately press and hold the Start/Stop button until the Demo-Mode is activated, approx. 4 seconds.
Demo-Program deactivation: Follow the instruction for Demo-Mode access above.
Aug 16, 2014 | Washing Machines
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
My miele touchtronic w 3039 will not start. the waterproof system activated keeps blinking in the display window with the start button blinking as well and beeping
Feb 16, 2010 | Miele W2203 Front Load Washer
THE TWO DOTS IN THE CLOCK DISPLAY KEEPS FLASHING--CVA4075--THE TIME IS WORKING BUT THE TWO DOTS FLASH CONTINUOUSLY how can I correct this problem?
The flashing dots cannot be turned off they flash on all of Miele's products with similar displays. Do they really bother you?
Oct 08, 2009 | Miele CVA4070 Coffee Maker
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
