My Ricoh aficio 3224 c giving error sc195 - Office Equipment & Supplies
2 Suggested Answers
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
Ricoh 3224 Prints have fading in the middle of the page?
Verify the OPC drum and the polygon motor scanner glass,something is dirty.
Feb 13, 2013 | Ricoh Aficio CL3500N Laser Printer
HOW DO YOU GO TO SERVICE MODE ON A RICOH AFICIO 3224.I JUST FILLED THE OIL BUT STILL GETTING SAME ERROR SC570.DOES THE OTHER PIPE ON THE OIL TANK CONNECT ANYWHERE BECAUSE IT IS JUST HANGING THERE.
Hello Peter,
Once the device has been neglected for oil long enough you will get this error code. Usually people don't wait until the code occurs. You WILL INDEED need to go into service mode. To do this,you will need to follow a fluid 3 step process. First locate the "CLEAR MODES" key located obove the 9 key pad. It is yellow. Now locate the red STOP button located below the 9 key pad.Ok, to enter service mode you will need to press "Clear /Modes"and release,then press the numbers "1,0,7" in a 3 step sequence and release, then press the red STOP button and HOLD it down till the device beeps. The screen will change and say service mode. Press "COPIER". The screen will change again. Using the keypad press 5,8,1,0 and then press the pound sign {#}. You will be prompted/asked to EXECUTE. Press EXECUTE. Now unplug the device while in service mode after the execution of the 5810. Wait a sec, plug her up, and you are done. Have a good day and let fixya know I helped. :-) SPINAL
Jul 23, 2011 | Ricoh Aficio 1232C Color Copier
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
I need enter in factory service mode to enter serial Nº by code SC195 in aficio 1232.
press the clear mode key and use the key padto enter '107'hold downe clear\stop key for 3 sec enter the service mode and press on the touch panel sp mode and you can work what ever you like
May 20, 2010 | Ricoh Aficio 1232C Color Copier
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Error message sc 172 on ricoh aficio color 2103
You'll need a tech on site for this one, but it may be difficult to source parts if required for this old box. One of the following situations has occured:
• Poor connection of CCD
harness
• Dirty optics
• Defective lamp regulator
• Defective main scanner IPU board
• Defective CCD
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
42 people viewed this question
k24674
jasbo
jasbo
