Question about Virginia Mill Works Engineered 1/2 x 5 Colonial Plank Handscraped Engineered Flooring
Where can I find this flooring?
Lumber Liquidators advertises that they have it but it (and many other colors) is discontinued and is no longer available. Any suggestions as to where I can get this flooring?
Need additional flooring
Try lumber liquidators. Make sure it's same width and height.
Jan 06, 2014 | Building Materials
Bathroom floor rot
take up the floor. lay new underlayment ( I recommend concrete wall board at lumber yard), then add top surface (ceramic, linoleum, wood)
good luck
Neil
Nov 09, 2013 | ProteShield 1-Gal. Elastomeric Waterproof...
What is treated lumber?
Treated lumber is wood that has been 'treated' with chemicals to slow down the decay process that naturally happens.
Sep 09, 2013 | Building Materials
Is it possible to order lumber over the internet?
Yes sure you can. You can order lumber on line and have it delivered to your home or workplace.
Here's an example of a site that does lumber deliveries;
http://www.fixya.com/support/t15886481-possible_order_lumber_over_internet
Jan 15, 2013 | Building Materials
Eagle 462c will not power up
I called Lowrance and since Eagle has been discontinued, they no longer service them. However, they will offer to upgrade to Lowrance. I ended up getting a HDS-5 for $480.00. Not a bad deal since my Eagle was toast.
Sep 29, 2011 | Eagle Fishelite 642c Color Fishfinder Gps...
Where can i get a color wheel for the toshiba 62hmx95
the part number for the color wheel is 75004307 unfortunately that color wheel has been discontinued and no longer available.
Aug 08, 2011 | Toshiba 62MX95 Television
I want to find replacement parts for the ADF feeder, specifically 57-0100-000 ADP Pad, and 57-0110-000 Roller Assembly
Hi, I don't know if it's permissible to advertise but we currently sell the assembly for the Xerox Documate scanners. As far as I know the scanner's discontinued, and the pads are getting pricey so consider how much longer you want to wait before replacing the scanner.
sales at sprucecomputer dot co dot uk if anyone is desperate
Nov 07, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Rca p56740bg tv
Most of the screen cover for sets older than 8 years have been discontinued,get the size of your screen leaving about 1/8 of and inch around the screen,you can get your local lumber or hardware store to cut pexie glass to fit,get velcro and apply to sides of screen to attach glass,make sure to sand any sharp sides before attaching.
Dec 31, 2007 | RCA P56830BL 56" Rear Projection...
Virginia Mill Works Engineered 1/2 x 5 Colonial Plank Handscraped Engineered Flooring Logo
Top Virginia Mill Works Engineered Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Virginia Mill Works Engineered Building Material Expert? Answer questions, earn points and help others
