Question about Sony Handycam DCR-HC42E Mini DV Digital Camcorder
No Display is coming on the Flip out LCD
LCD Display showed display without color however after sometime it showed no display at all. however i am able to browse photos using lcd if i correctly navigate. But there is no display all. NB : Also specify part & cost if any required. Thanks in advance!
  • amitm Sep 07, 2007
    The problem was actually the flexible cable connecting the LCD panel.
    The Flexible cable was replaced by SOny and now the display is coming on the LCD panel.
    Thanks for the help.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
CCD sensor seems faulty . Sony should repair free of charge but otherwise it is not an expensive repair to perform : requires 1 hour labout at most. ( the componenet itself is not expensive ).
Posted on Aug 28, 2007
Tv problem lines across screen
On a modern LCD TV screen, white (or any color) vertical lines appear when the individual "tab bonded" wire connections of the ribbon cable servicing a column of pixels on the LCD display begin to fail.
If the column wire is damaged and "stuck high," one of the 3 LCD display colors will show as a solid line.
If the line is white, all three colors are "stuck on."
This could be a manufacturing defect of the panel, or a result of the TV operating in harsh temperature conditions.
Alternatively, the timing controller board (t-con) may be failing and not sending signal to the display in the first place. It could also be a loose connection of the ribbon cable between the t-con and display.
Test sequence:
  • Reseat ribbon cables from display to t-con.
  • Try replacing t-con. (Sometimes, solder re-folwing the t-con fixes the issue)
  • Try replacing display. (Or, try applying pressure to the tab bonds)
Repairing the tab bond of an LCD display is a daunting, specialized task. Some folks have managed to fix them with heat guns or shims between the case and LCD (e.g., [Front Page] - Article: Howto: Repair LCD Tab Bond and TCON Issues), but those are hacks, at best.
Sep 11, 2018 | Televison & Video
My other computer, G4 Macbook Pro, has a screen issue. When it is turned on and in process of coming up, the screen shows large sections of odd colors such as light pink or light green or light blue. Then...
Connect an external display to the computer. If the lines and distortion shows up on the external display its the video card, which is attached to the logic board. So, the whole logic board will need to be replaced.
If the lines and distortion don't show up on the external display the issue is the LCD module, which will need to be replaced.
Jan 30, 2011 | Apple PowerBook G4 Mac Notebook
N70, cell is on,lcd ok but not display.
That should be hardware problem, maybe your display is bad, or maybe display ic isn't functioning properly or display connector's problem. Sometimes only cleaning will fix this if there's no internal damage. Good luck.
Thanks for using FixYa.
Jun 12, 2010 | Nokia N70 Cellular Phone
No display
What you have here is a LCD problem. LCD means Liquid, Crystal, and Display.
If it's a flip up phone, check if it is detachable and replace the flex, but if it is not detachable, you have to change the flex and LCD. If it is a LCD without flex, you have to use another LCD, it will then display.
But if after following all this instructions and the screen does not come up, then take the phone to a technician for proper repair.
Jan 12, 2010 | Nokia 5310 Cellular Phone
Display on pearl flip when closed is always black
John-
It is possible the backlight or the LCD itself got damaged. The good news you is you can replace it.
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Blackberry Flip 8220 LCD screen Replacement Guide
Jun 03, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
White Display
Here is two solutions:
1. Grab a LCD Color Tester, Run it through RGB.
- If it is still white its the LCD
-If it not at all either the inverter board is bad or the mainboard.
2. Sometimes its brightness control, look under the manual.
Apr 18, 2009 | Princeton Digital VL1716 17" LCD Monitor
My moto v3x lcd display problem
U can try to change the LCD leber first,or U can adjust the flip see the display have respond or not first to make sure the laber for Lcd display is damage,if U sofe the problem,reply me,rose89my@yahoo.co.uk,thk!
Nov 15, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Display Issue
I think your right although have you noticed when you change a TV from PAL to NTSC,(and other display settings) that the screen turns green. Is this a possibility. If your LCD was fine B4 and the problem has occured without your help then sorry to say it sounds like the moniter is playing up. Anyway its just a thought.
Good Luck
Clapster
Jan 21, 2008 | Toshiba Satellite M35X-S149 Notebook
Sony Cybershot DSC-W100 LCD viewer
do you guys have a grainy display, that makes it look like there are less color variations?
for example, if you take a picture of something that varies in color from one side of it to the other, with an infinite variation in one color to the next; do the colors separate into grainy spotches, as if it lost some color display capabilities? mine did this, if i took a picture of something that had different hues of one color, they would all flow together into one splotch, and upload fine.
so i sent it in and they said they "reconnected the lens-flex" among other routine things. problem fixed.
but then i sent it in again and they said they did the same thing, but the problem this time around was my capture-mode dial was glitching, the display was FINE. sadly they didn't do jack to fix the dial it and it still screws up. it will switch back and forth from adjacent modes without me turning it.
i'm happy with this camera but its a pain sometimes. if you guys have warranties send your units in ASAP to get it fixed for freeeeeee.
best of luck, i can't suggest anything beyond that.
Oct 07, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Handycam DCR-HC42E Mini DV Digital Camcorder Logo
127 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
