B&Q airforce evaporative air cooler KDT120-80B
4 Suggested Answers
  • 38 Answers
SOURCE: my cooler is blowing very slow can hardly feel the air
it could be any of three things.
1. its a variable speed motor and will not blow hard unless you have an extreme cooling need (5 degrees or more away from set point)
2. You have collapsed duct work.
3. Dirty evaporator coil, or filters preventing proper air flow
Posted on May 08, 2009
SOURCE: evaporated cooler is not filling up with water
yes ur water pump is not working properly..
ur will have to check it
Posted on Jun 29, 2009
  • 1010 Answers
SOURCE: Can anyone tell me the model of this Bonaire evaporative cooler, as I have recently purchased house and don't have manual. Wondering how to carry out a filter clean from the controller & pre-cool
Go to the Bonaire website for manual
Posted on Mar 09, 2013
External unit on my walk-in cooler will not shut off. Seems to be due to the Ranco Pressure Sensor. How do I fix or adjust?
Diagnosing Walk-in Coolers & Freezers Problems
blog.uscooler.com/walk-in-cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
Maintaining & Cleaning Your Walk-in Cooler or Freezer
blog.uscooler.com/maintain-walk-in-cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
[PDF]INSTALLATION & SERVICE MANUAL - Polar Leasing
Dec 10, 2015 | Refrigerators
Year old Symphony Winter evaporative cooler won't turn on, not even just the fan. Borrowed from friend, had to put on side to get in car.
Sounds like it's not getting power. Open it and check for an inline fuse or a reset button.Check the power cord for continuity first though, and make sure you're using a proven power outlet. It could be drawing too many amps, and tripping the circuit protection on that particular outlet.
Aug 21, 2013 | Symphony WINTER Evaporative Air Cooler
I have a MasterCool II MC63/64B and the thermostat has gone out. Since MasterCool is out of business, what model/brand would I replace it with.
If you are just running the evaporative cooler any single stage thermostat will suffice. You can buy them at OSH, Home Depot or Lowe's and probably Ace Hardware.
Aug 03, 2011 | Mastercool 67680 Evaporative Cooler Air...
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
Air evaporative cooler
The motor is over Amped and is cycling on the thermal overload protector. Make sure the original panels of the cooler are all in place for both inlet and outlets. if that is ok ensure that the voltage is adequate when the motor is running and drawing electricity. Most are not rated to run under 105 volts AC.
Jun 07, 2010 | Mastercool 67680 Evaporative Cooler Air...
Hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
Dec 18, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
Evaporated cooler is not filling up with water
Jun 29, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
