Question about Garden
Weedeater xr 30
What is the gas mixture ratio for the xr-30
  • 107 Answers
SOURCE: oil to gas ratio
heres a link for homelite service manual
http://www.odref.com/homelite/string-trimmers/service%20guide.PDF
pg 4 states that fuel/oil mix is 50;1
2.5 oz per gallon
Posted on Apr 20, 2009
SOURCE: gas/oil mixture for ryobi weedeater
It is 2.6 fl oz of oil per 1 gal of gasoline.
Posted on Apr 29, 2009
#1 Taper
  • 1040 Answers
SOURCE: homelite weedeater smokes
Yes, you have too much oil in the gas.
Jim
Posted on Jun 16, 2009
canbruce75
  • 1776 Answers
SOURCE: Gas/oil mixture for my Homelite Trimlite weedeater 25 cc
50:1
Posted on Jul 12, 2009
  • 316 Answers
SOURCE: Need to know the gas ratio mixture for a Echo Gas Trimmer GT2400 [serial#004349]
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Posted on Feb 19, 2012
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
What is gas mixture for weedeater poulan pro 25cc 17" cut
40:1 ratio is the manufature spec for 2 stroke units. unless it is a four stroke then there is no mixture just a good quality gas.
Jun 03, 2014 | Poulan WeedEater Hedge Trimmer 25cc Engine
Does the 28cc and 25cc weedeater use the same oil and gas mixture
Yes they will use the same mixture, it doesn't matter on the size of the engine. I would recommend using a 50:1 ratio. That equals out to 2.6 oz of oil per gallon of gasoline. Hope this helps, Daniel.
Oct 26, 2011 | Husqvarna 28cc Gas Line Trimmer
What is the fuel to oil mixture ratio for my gas featherlight weedeater?
That oil/fuel mixture would be 50-1 or 2.8 ounces per gallon...
heatman101
Sep 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Won't stay running for more than 10 min
Not true. It is important to read the package and fuel/oil mixture ratio ie: 40:1, 50:1, 32:1, as long as the mixtures are the same, you can use one tank for all of the 40:1 tools, one can for all the 50:1 mixtures, one can for all the 32:1 mixtures. essentially all the 2 stroke oils are the same, the numbers just designate parts of oil(quantity) to parts of gas.
Aug 02, 2009 | Garden
What is the gas to oil mixture ratio for a GTI15 weedeater?
40:1 is the recommended ratio by the company that made the weedeater. But it has been my experience that 32:1 allows the engine to last longer.
Jun 24, 2009 | Garden
Gas to oil ratio
this mixture for this weedeater is 40:1 or 40 to 1
Hope this helps You
please rate me
Jul 19, 2008 | Electrical Supplies
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
