Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD440 Hello.... I have the above washing machine thats decided to go **** up.... Symptoms... The machine will carry out a Prewash programme successfully.. all the way through When I select any other programme the maching will go through the wash cycle but when it moves onto the rinse and spin (Light Comes on) the machine will just alternate between forward and backwards slow tumble.... If I then turn the machine off and back on the wash light will keep flashing .. I have emptied the filter at the base of the drum and checked the pump not blocked all looks clear the water coming in has been checked ie turn each off and on one at a time and can confirm that water enters the detergent tray.... Questions: Whats different between prewash and normal wash... might help to solution.. Im down to 2-3 possible things ... Heater element / Sensor but i presume that pre wash would have stuck if this was shagged.. The presure valve at the top left of the unit behind the detergent tray or lastly the PCB board if so where can I get replacemnet.. Thanks in advance Jim Bailey
  • Anonymous Mar 23, 2014
    soapy water comes out of the valve at the top, back of the washing machine. we use HE detergent and have been careful not to use too much.
On the power pcb panel, there is an eeprom. This gets corrupted and throws the machine into a frenzy. A replacement should include a new pcb and a new eeprom. Only from dealers unfortunately.
Posted on Sep 17, 2007
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 washer/dryer. 1st problem was it wouldn't drain so I cleared the pipe. Now the machine 'wash' light flashes during a wash. The washing machine doesn't seem to hold the water...
Make sure that the outlet of the pipe is at least as high above the floor as the top of the machine. If it is lower than the level of the water, it will just drain - there is no shut-off valve to stop it from doing this. Please rate this answer.
Jun 17, 2011 | Hotpoint Washing Machines
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
u might have a blockage in the drainpipe. hope it helps. good luck!
Jun 16, 2008 | Hotpoint Aquarius WD640 Front Load...
WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
Feb 03, 2008 | Hotpoint Aquarius WD640 Front Load...
WD440 conditioner inlet /outlet appears blocked
Hotpoint WMA36 Washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2008 | Washing Machines
WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Nov 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
664 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
