Question about Health & Beauty
Heel spur lack of calcium .is it true? - Health & Beauty
I am feeling pain specially when I stand my heel
Could be a coupe of things.
could be you have stood on something sharp and have something stuck in it, thorn, glass, wood or metal splinter.
you may have been bitten by a spider.
you may have a heel spur. These can be removed surgically. They are explained here
http://www.webmd.com/pain-management/heel-spurs-pain-causes-symptoms-treatments
Heel Spur Causes Symptoms Treatments and Surgery
Apr 28, 2016 | Health & Beauty
Tip
Tips on high heel shoes
The high heel shoes have never been out of fashion in women's world.The high heel shoes push the buttocks of women backwards making a perfect balance between the hips. High heel shoes have also shown some actual benefits for women, as some experts are finding their use in exercising the pelvic floor muscles of women.The high heel shoes can even damage feet if used excessively for a long period. You should not wear high heel shoes all the day.
on Oct 27, 2010 | Clothing Accessories
Both feet hurt on and around the heel
Could be heel spurs or plantar fasciitis. Stretching and icing work well to relieve pain. Freeze a water bottle and roll your foot over it. If this doesn't help then you may need to see Dr. for a cortisone shot.
Oct 26, 2013 | Health & Beauty
I want to know that NOW FOOD BONE STRENGTH 240 CAPSULES CAN HELP TO CURE OSTEOARTHRITIS PAIN ON MY KNEES? iF NOT WHAT PRODUCT i SHOULD TAKE TO HEEL ME? PLEASE ADVISE ME SOON.
No there is no cure for osteoarthritis but the calcium supplements may help relieve the pain. Vitamin K2 should be with any calcium supplement, it help get the calcium to the right place and absorbs easier int the bones
Oct 04, 2013 | Now Foods Bone Strength, Capsules, 240 ea
My kenmore 665.13719k600,wont clean the dishes
Try cleaning your dishwasher using a dishwasher cleaner. this will clean out the build up. There is one that i recommend and it is called Dishwasher Magic.
You can prevent this from occurring in the future by, installing a Water softener in you home. this will heel the build up.
Jun 19, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
Exploding capsules
Exploding capsule is caused by lack of FAP pressure. The reasons are a few: 1-machine leaking, 2-inf pump worn out, 3- 3way valve not working because of calcium buil up, 4-membrane assembly is broken, 5-labyrinth is clogged with calcium. Good luck
May 10, 2009 | Lavazza Espresso Point Capsule Machine
My saniflow is running constantly.
Shut the water off to see if it stops running. if so the flush valve seat has calcium build up and needs to be cleaned start by using CLR to help dissolve the calcium. If running water is not the problem, the mercerator is jammed with paper and will need to be cleared.
Mar 27, 2009 | Saniflo & Saniplus& Macerator Pump
I CAN`T FIGURE OUT HOW TO GET THE HIGH HEELS
Gamefaqs dot com was made for that problem
Dec 30, 2008 | Nintendo DS Console
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Whining diff 1986 silver spirit
Height control action noisy, emitting squawks when operating. Air in heigt control system. Bleed system.
Jul 13, 2008 | 1991 Rolls Royce Rolls Royce Silver Spur
Health & Beauty Logo
650 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
